Home > Maintenance & Modifications > Spring removal
RRUK
Spring removal
According to RAVE you need a spring compressor to remove the springs.
is that the real world or can you just drop the axle down enough to remove? 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #122251 7th Feb 2012 11:38pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
On my Puma i removed the rear spings without a compressor but needed one for the fronts. they are very cheap now and save a load of hassle
http://www.screwfix.com/p/coil-spring-comp...fAodejOhgg BM52
Post #122253 7th Feb 2012 11:41pm
Dave-H
I did mine without a spring compressor without any drama .... front and rear
Just watch the flexi brake pipes.. Wink Guns and Landrovers .... anything else is irrelevant.
Post #122434 8th Feb 2012 8:40pm
RRUK
Did you need to jack the chassis up so that you could lower the axle far enough or not? 2016 D4 HSE
Post #122440 8th Feb 2012 8:46pm
landy andy
No need for spring compressor.
Just need to jack chassis as high as you can, take wheels off, so axle can drop lower, and you may have to remove anti roll bar clamps if fitted.
Andy
Post #122459 8th Feb 2012 9:12pm
jst
i have never used a spring comp on a LR. as above jack the chassis up then drop an axle as far as it will go watching brake pipes etc, may need to remove a shock on the rear to do it. front shocks obviously need to come out to get the spring out. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #122478 8th Feb 2012 9:38pm
BigMike
Never needed one. You can also lift the front with a hoist, does the same thing. Whilst you're at it, put open turrets in, makes the job Censored easy the next time you do it.
Post #122486 8th Feb 2012 9:49pm
