Home > Off Topic > 3g dongle?
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
3g dongle?
Hi, just spent a frustrating hour trying to find out whether and/or how I can obtain a 3g/internet dongle or similar for my laptop while travelling around France.
I am sure there is a solution but i can't see one yet. The idea is to recieve/make calls on my phone as usual and only check emails on the laptop and use the laptop for research, booking hotels etc. Probably use it to watch a bit of internet TV as well....
Alternatively route through the phone but at the moment options seem limited and O2 seems very expensive abroad.
Any ideas would be appreciated.
Thanks. BM52
Post #121977 7th Feb 2012 12:03am
JWL
Have a look to see if you can pick up a PAYG set up on the continent using their local networks instead of tieing yourself into a contract in this country and having to sort out roaming services that you may well get charged for. An unlocked dongle should be easy to pick up before you go and then just pick up a prepaid sim in the area you're in.
Just a thought.
Post #121978 7th Feb 2012 12:09am
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
My company use the dongle that you can pick up from any phone shops, I think ours are from 3.
They just link in with the nearest major telecom provider so no need to worry that a specific provider (say Vodafone) do not cover the area you are in as if any provider does cover it links with that signal. It may cost a bit more but to avoid that make stops in cafe's as the majority have free wifi as well as hotels and hostels. That's what I did travelling. if your using yours just to book flights etc then you could probably just get away with a pay as you go. Type in
http://www.uswitch.com/broadband/guides/broadband_abroad/
There's also a link on the left to what the best dongle bundles are. Hope this helps ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #122002 7th Feb 2012 8:50am
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Ive got a BlackBerry on Vodafone that i can tether to my netbook and laptop. If im travelling in Europe then i call them and add a "pack" to my contract for £10 a month that gives me 25mb a day in most European country's and i can start it and cancel it any time i want, just the minimum is one month costing £10. Ok not much good for watching TV but for general browsing and email its more than enough.
Pete.
Post #122052 7th Feb 2012 12:33pm
noworries4x4
I have got a vodafone dongle c/w clip on aerial that works very well in the uk but then i put a bougie tel payg sim card in it out in France, i just went into a hypermarche and got the one with the cheapest data and put 20 euro on it, worked for ages then i did not know how to top it up, my French is good but not that good. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #122232 7th Feb 2012 10:41pm
