![]() | Home > Maintenance & Modifications > How to lower my suspension lift down to 2 inches |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6048 ![]() ![]() |
You have at least a two inch lift.
Phone Gwyn Lewis, he will tell you what the correct dimensions are for standard, measured top spring seat, to bottom spring seat. The only proper way of telling. I think they are something like 250-260 mm front, 310-320 mm rear. I think. Andy |
Er...yes...lift
![]() But shout it at them in German because life is also terrifying and confusing... |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2038 ![]() ![]() |
As far as I can tell it doesn't have cranked radius arms or castor corrected panhard rods either.
The more I think about it, the more I think its a good idea to drop it back to Std height. I seriously doubt I shall ever do any serious offroading that requires such a lift. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Can't get over how skinny your Discoverers look on 17" rims compared to mine on 16"s. Almost sporty
Skinny?
Sporty? Any other Spice Girls you want to name! ![]() ![]() Click image to enlarge 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Aaahhh - Spice Girls. Soft porn at its best
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 ![]() ![]() ![]() |
![]() ![]() ![]() ![]() Click image to enlarge dsc00703 by .:ay4alex:., on Flickr I'd certainly say that it has potential to be 4". unless it's only ever used off road, better off dropping to standard if you don't want to run particularly chunky tires. otherwise a 2" would give a happy medium ![]() |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 589 ![]() ![]() ![]() |
OK this is another effort at determining what lift you have, although not foolproof as I am unsure what I have
![]() I scaled my roof length to the same as yours in the picture 70mm then measured from the wheel centre to the spat. They are quite similar at 17mm and 18mm so therefore you have a 1mm lift ![]() ![]() ![]() Click image to enlarge ![]() |
