![]() | Home > Technical > small leak |
| Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026
Google Defender Water Ingress Manual...sealant into window rubbers, take off false window hinge and treat with sealant, roof to windscreen frame etc, gutter, sunroof, cappings, etc etc
| boxer Member Since: 12 Jun 2011 Location: north yorkshire Posts: 48
Thanks for that will order some sealant asap, should i run some over the foam joint under the windscreen gutter?
That would be tricky. I sprayed mine with ACF-50 and then put a more enduring layer of Wurth Rust Protection Wax which provides a tough stickeable film over the foam to hopefully repel any water. Both are aerosols and there will be other products suitable i am sure. The Wurth stuff is good as it is clear and quite tough
This was my solution also for the foam strips between the rear top and cappings on the rear tub! It doesn't show you have done it |
| XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632
Zag - Is your Wurth product what they call 'Wurth corrosion protection spray'?
Pete |
That's the stuff Pete. Dunsfold DLR put me onto it
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
on Bob's advice, I order one of the last 1kg tins of dum-dum in the country...
| Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478
i had the same problem turned out to be my gasket behind the windowscreen hinge
I left two messages and ordered online as well just after Bobs post but didn't hear anything! I have a new tin somewhere just can't find it Put yours up on E Bay Steve |
it's not arrived yet, but fingers crossed
He's been flooded with orders I expect, if you don't own a Rover then it's a no no....
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
Apart from the confirmation email there is no further contact.
Mine turned up three days after ordering on PJS ? couriers. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
| Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 242
Yep just had a email from JRW saying they only sell to those who are buying a screen from them. Will Defender 90 XS TD5 (03 Reg) |
| rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297
now that's given me an idea. Here was I waiting for a couple of dry days so I can seal those gaps front and rear (where the foam strip is) with black mastic as rain is wicking through them into the footwell but I have an aerosol of Fabsil (used for waterproofing caravan awning roofs) in the shed so I might soak them in that instead to see if it works Thanks Zag ! |
Try this lot - about half way down the page.
I couldn't get the checkout to work when I tried at the weekend. http://www.repairproducts.co.uk/page4.htm Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
