Home > Maintenance & Modifications > fitting tablet pc in a defender, for mapping etc
pathfinder
1989 Defender 110 200 Tdi USW Rimini Red
I have been using Memory map for years on a PDA and have found it invaluble, however technology moves on fast so I have installed memory map on an Ipad that I recently bought, I mounted it with a cheap windscreen suction cup mount but found that it had a tendency to fall off! so I worked out what I would need to build a more secure mount, and here is what I have come up with Very Happy
firstly is the ball fixing.
here is the cradle fixed and positioned out of the way.
Angled around for driver view.
:D
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  One wife Livid!
Post #119790 30th Jan 2012 4:33pm
kzycnn
Very neat and tidy. I have mine mounted on a flexible stalk (courtesy Leeds Thumbs Up ) with the base next to the passenger seat bolts - not utilising the actual bolts as I also have a Mud Tray fitted so had to move the mounting over a bit. Do find your solution much tidier as, again, with mine, you have to be careful not to obstruct gear changes and/or switch gear - difflock engagement needs a bit of deft elbow work Smile Tony
Post #119803 30th Jan 2012 5:20pm
neat job, the ram mount kit is expensive but great quality, I have mounts in both my land rovers Thumbs Up
if you look hard enough on the ram mount website, you can find a pdf catalogue with all the mounts, fixings etc
Post #119836 30th Jan 2012 6:58pm
bob neville
Very nice set up Thumbs Up
I am trying to work out a similar solution on my Puma, I find the flexible arm moves too much and my navigator has to hang on to the tablet pc Shocked
2013 Defender 90 CSW - sold
Post #119854 30th Jan 2012 7:35pm
hey Bob,
here's my set up in the puma (i also use the same arm and cradle in the tdi)
I've not tested it in the puma off road (yet!)
Post #119859 30th Jan 2012 7:55pm
bob neville
Thanks Steve - that will work Thumbs Up
Do you have the part number of the ball fixing you used on the grab handle ?
Thanks
Post #119865 30th Jan 2012 8:03pm
Thanks
Bob
hi Bob
i think it's "Base with Ball and Straps (RAM-108B)" = �14.43
Steve
Post #119872 30th Jan 2012 8:11pm
bob neville
May have answered my own question - RAM-B-108B ??
Post #119874 30th Jan 2012 8:12pm
you did but I just beat you Whistle
(it comes with 2 clips a large and medium and a rubber sleeve)
Post #119877 30th Jan 2012 8:14pm
bob neville
Thumbs Up
Post #119879 30th Jan 2012 8:19pm
leeds
Ram mounts are extremely useful kit. Ipads etc can be mounted on the Defender grab handle. Also can be mounted on flexi arms.
Flexi arm is mounted under seat rail bolt.
Can not find the photo of the 2.5" ball mounted on the bulkhead.
There are 4 different sizes of ball dependent on the weight of the item to be held.
We do have a range of Ram Mounts in stock.
Brendan
Post #119895 30th Jan 2012 9:02pm
TJ101
I bolted my ram ball to the grab handle,, now in its 4th Puma,, works fine,,
Run with a tough book, being a bit heavy and would move,, but only on rough washboard roads in Morocco and the like
For a later trip, tried a touch screen, that worked better,, but the I pad works the best
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #119897 30th Jan 2012 9:03pm
Tim - you must show me how you do that "discreet" wiring :thumbsup:
Post #119911 30th Jan 2012 9:30pm
My Ram Ball is bolted to the MSS cubby (neat wires Whistle )
Post #119915 30th Jan 2012 9:35pm
TJ101
bpman wrote:
Tim - you must show me how you do that "discreet" wiring Thumbs Up
Fitted only for a 3 weeks trip,, left no holes, cuts, marks or brusies Very Happy California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #119925 30th Jan 2012 9:53pm
