![]() | Home > Technical > Anti Roll Bars and Alloy Wheels |
Knot Yet Member Since: 01 Mar 2010 Location: West Sussex Posts: 197 ![]() ![]() ![]() |
Should have the following as part of the Style pack (as of August 2011):
Boost Alloy Wheel & Continental ContiCrossContact AT Tyre Front & rear antiroll bar Locking Wheel Nuts Metallic Paint Tow Ball, Drop Plate and Electrics Hope that helps Jean Defender 110 Puma Utility XS |
taffyscouser Member Since: 08 Jan 2012 Location: Bath Posts: 28 ![]() ![]() |
Must be a bitsa then? There are definitely none on the front or back of the vehicle. All the other stuff is in place. Are they really required with the alloys? Would make a great bargaining tool if they should be there and are missing. Insurance problems to a new owner?
Personally Ive found they make the ride much more comfortable as less rolling around corners.
If its sold with a Style pack they should be there - the alternative is to request the print off that states exactly what was included when it left the factory - this will identify if it should have had the roll bars fitted Not sure re the insurance but principal dictates if sold with Style pack they should be there ![]() |
Thank you so much for the help and I will be double checking with dealer tomorrow re the exact spec on it. As you say, if it IS a style pack they should be on there. If they have cobbled some extras to make it almost equivalent to a style pack then ok
Exactly my sentiments - good luck and keep us updated
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
2007 I know but county with alloys should have had anti roll bars fitted, then as now it came with the alloys, not done at the factory
![]() I was just happy it was the correct colour and lenth ![]() |
I had an 03XS came supplied from the factory without A/R bars .. soon fitted front and rear, improved road manners
Dean Watson Member Since: 17 Jul 2011 Location: Derby Posts: 265 ![]() ![]() ![]() |
Hi
At the risk of sounding less than experienced what does an anti roll bar at the front and back look like! ive got a 2011 my xs dc and would like to know what i should have! Deano |
it's a U shaped bar that is fixed to both sides of the chassis and also on each end of the axle, about 20mm thick. it limits the axle movement, hense is makes for a firmer ride but less articulation off road. so good and bad depending on how you use the truck |
If I get an even better price I may haggle them down even further and fit a set myself. Are these readily available second hand? or should I insist dealer fits them from new?
I vaguely remember something in LRO about fitting yourself so guessing possible, my understanding is unless you wish to do hard core off roading and need greater articulation, it's better to have them. Also not sure where you would stand if they came fitted and then removed, if the vehicle was then rolled in an accident I wonder how the insurance would stand?
Probably a good idea to ensure they haven't been removed in the first place ![]() |
