Home > Maintenance & Modifications > Starting issues
JWL
Starting issues
I have one of the most irritating problems that you can get....... my TD5 has an intermittent starting problem. Sometimes when you turn the key all you get when you turn to the start position is a solonoid click at the starter motor, sometimes it will get as far as engaging the starter and start to turn the engine over then stop.
Sometimes you can go days with no sign of trouble and you think it's fixed, then like today, it can take you over a dozen attempts to get it going(you just make sure you don't stall when out and about Whistle )
I've checked and double checked the battery terminals, I have no concerns over the battery condition. Taken off and cleaned the terminals on the starter motor. Double checked the earth strap near to the starter and put another one on. Fiddled, faffed and swopped the relays behind the fuse board, no problems there. I'm begining to suspect the ignition switch now, when it's in it's won't play mode, no matter how you twist, lean, push and pull on the key it seems to make no difference. But, I do get the impression that holding the key in a certain fashion does make a difference.
The question I'm getting round to is that if I go and replace the ignition switch am I right in assuming that I'll interfere with the alarm/immobiliser and, apart from having a different key to the doors cause me a bigger expense. Could I take the "start" wire off the back of the switch, extend the wiring to a new push switch and thus keep the alarm/immobiliser intact as is? This way, the key is still needed to start the motor but the function of actually turning the key to the start position would be taken over by a seperate button which may well be hidden in plain sight.
Post #118538 25th Jan 2012 11:00pm
landy andy
Think it will be be a sticky solenoid on the starter, very common on the Td5, but at leat the starter is easy to remove, don't even need to disconnect the battery.
Andy
Post #118541 25th Jan 2012 11:04pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Hi it sounds as it could be the contacts in the starter motor have a look on ebay for the parts only bout a tenner best way to do them is take of the starter then remove the cover bolts and its pretty obvious then how it goes in
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #118542 25th Jan 2012 11:05pm
when did this start happening ?
did your truck get wet ?
have you played/modified any of the electrics ?
Is it dry under the passenger seat ? (IE is the electrics / boxes all dry)
have you had any problems with the immobiliser ?
can you use a nanocom - ie is there any error codes for the immobiliser ?
Before buying stuff, check the above Thumbs Up
Post #118543 25th Jan 2012 11:06pm
JWL
I must admit I have been avoiding the obvious.........it's dirty under there Whistle but I do have an oil leak off the back of the rocker cover that makes its way down and all over the starter motor so a damn good clean wouldn't go amiss in that area at least, don't want to be having a clean motor, it gets a clear passage in the school carpark Whistle
Post #118549 25th Jan 2012 11:12pm
I wonder if TD5 Defenders still use the spider unit as part of the immobiliser, as per the 300tdi Discoverys? The reason I ask is you're describing the exact same fault I had on my old Discovery, which turned out to be this unit. I overcame it by replacing it with a bypass that LR produced because so many went wrong.
Of course, if Defenders don't use this unit then that's irrelevant Rolling Eyes Darren
Post #118550 25th Jan 2012 11:13pm
pom
I had exactly same thing with my puma and it was the immobiliser.
Soon as it happened I locked/unlocked using the remote and it started right away.
Pom
Post #118557 25th Jan 2012 11:19pm
JWL
About a couple of months ago, now getting more frequent and irritating
Erm once or twice
The bits I've done have been add ons with a new power source from the battery
You 'avin a laugh? It's got half the Plain in there, now turned to dust after that Christmas Jaunt
None
Can't get to one at the moment, tops out on my wish list
Cheers for all the suggestions, I still might do my seperate starter switch though as a security measure against a casual theft, might just confuse a scroate Whistle
Post #118564 25th Jan 2012 11:45pm
landy andy
Are you sure it is not your fuel pressure regulator leaking?
Another common thing, is the FPR leaks diesel on the starter, then it fails?..
Worth a look.
Andy
Post #118570 26th Jan 2012 12:07am
JWL
Looks like I got to give myself a kick up the Censored and do a bit more detailed investigating, just reluctant at the moment especially as it's persisting down at the moment, might be sunny tomorrow Whistle Bit of a pain with working on the street Rolling Eyes
Post #118575 26th Jan 2012 12:36am
JWL
Went down the route of replacing the solonoid bits as per Landy Andy's suggestion. Went on fleabay yesterday morning about 8am and bought one, was on the doormat this morning. So that spurred me on and I've fitted the bits. Simple job to do, the biggest pain is the mounting nut on the "hidden" side of the starter motor, especially when you do find out it's a different size spanner needed than the other fixings. Took me longer to get it off than do the business. Still hour and a half later, soaked(why does it allways rain when the spanners come out? Bloody sunshine now and before Embarassed )
All back together and it works, well it worked all day yesterday as well but it took me 5mins to start it at one point this morning. Tried it repeatedly for five minutes or so and it only clicked once, just going to see what happens over the next few days. The copper contacts were pretty pitted and eroded in parts, I have got some pictures if anybody's interested so for the sake of 12 with postage it's worth a try.
Post #118933 27th Jan 2012 3:51pm
