![]() | Home > Puma (Tdci) > vibrating gear stick |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
hi its a common problem on pumas i have read some over threads with same problem and in work we had a customer with a vibrating gear stick, turns out its not the actually stick but the piece which the stick goes into if that helps
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Wrong... they were under the tolerance and LR dealers change them if within warranty. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
yanto Member Since: 03 Sep 2009 Location: caerleon Posts: 230 ![]() ![]() |
Thanks red dot but im out of warenty.do you know what part i need to get?
Thanks |
yer and when they change them it happens again and now the gearstick part is on back order due to land rover inspecting the fault so no not wrong
I knew a girl who would have loved to have had one
![]() ![]() 1968 1/32 scale Britains 109 Pick up. |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 ![]() ![]() ![]() |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339 ![]() ![]() ![]() |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 ![]() ![]() ![]() |
If you pull the gator down the bottom of the stick, you then can see two clip either side, un clip then shake, you should fine the weights on the stick rattle! A simple bit of card to wedge between the stick and weights sorted mine out
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2066 ![]() ![]() |
I don't get the bit about pulling down the gator...? I thought you would have to pull it up to get to the gear stick clips? Can someone explain what to do?
Thanks DAZ110 |
If you pull the gaitor up you e gotta sort all the carpet or whatever you have out! It's a right pain, loads easier to pull down
Ok thanks, will give it ago....anything to stop that vibrating!
