![]() | Home > Technical > UK Diesel vs Australian Diesel |
As it is remapped it may have something to do with over fuelling, is it black smoke under heavy acceleration?
Brian. |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
Actually I beleive cetane values are comparable. I run one of Gary Wood's remaps
LRO53 Member Since: 07 Jan 2012 Location: Australia Posts: 16 ![]() ![]() |
Yes under very very heavy acceleration. But it never did this in the UK i would have noticed im sure. I suppose with a different climate things could have changed... |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6048 ![]() ![]() |
Check you air filter, it could also be a failed MAF sensor. Those are they only causes of smoke for me now I have an Alive remap.
Andy |
I will check the air filter tomorrow. I know it had a new MAF sensor late 2009 but i suppose they can go again. I am the second owner of the vehicle. The first owner had this chip done in 2007. Here is what i got with the vehicle. Could the orgional engine management settings from factory be on this? As i was not aware the Newer type flashable ECUs had a slot or anything inside? ![]() Click image to enlarge ![]() Click image to enlarge |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 ![]() ![]() ![]() |
I work in Higham Ferrers and live a mile away and have never heard of him.
It's funny this is actually happening now im out in australia. I was thinking of taking the vehicle to Alive tuning as i was working up north for a period to have this remap that was done in 2007 checked out. I just never got around to it and things just started to get too busy. |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
An 05MY Defender will be flash mapped. No need to hard wire something in.
Probably worth getting some sort of LR diagnostics done, just to check over the vehicle and make sure it isn't something silly like air flow meter or an injector. |
