Home > Puma (Tdci) > I know King of the sparks is beating me but Milestone |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
Click image to enlarge Thats a lot of bum on seat for a 57 plate If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 Last edited by noworries4x4 on 22nd Jan 2012 12:38pm. Edited 1 time in total |
22nd Jan 2012 11:47am |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 609 |
May I suggest a revision to the typo on the Subject title.
200k and still going strong. How about a 'so far it's had a new this that and the other replaced' kind of list? |
22nd Jan 2012 12:12pm |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
Not had many replacement parts at all , No worries your not far behind i'm on 222,219
Original engine, gearbox , turbo, had a few of the usual water leaks, original drivetrain and axles, Big 2 stroke fan every tankfull 600ml |
22nd Jan 2012 12:13pm |
Ohh the warrenty list on mine is quite long, and as for how is it going, gearbox is howling noisy in 3rd and 6th, backlash in the diffs is terrible and the enging runs like a bag of spanners, still pulls very well still good on fuel, still great fun to have, oh and the drivers seat back has collapsed and the metal frame is digging in my back thats one of those urgent repairs, at the moment have a pillow wedged under the seat cover. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
22nd Jan 2012 12:23pm |
I am on 2nd Engine my first blew at 20K (proper destructed its self)
3rd gearbox (but that does not show a true story the first went at 50K was jumping out of 1st so they changed it, then 6K later that one was leaking so instead of fix the leak they did a parts warrenty exchange) 3rd back diff i am just wearing them out, heavy high mileage towing, they could have been adjusted but Land Rover just fit new. I am on my 3rd Turbo 4th Exhaust manifold ?? Egr valves it all just gets to hot. (and no its never been chiped) 2nd front prop, 1 set of rear axle drive flanges and bolts. Alarm and Imobalizer ecu and loom set up (it was in for 4 weeks trying to sort that) 3rd set of wiper drive units they just sieze up, 2nd Radiator, 2nd Battery and this one is dying. 2nd high pressure fuel pump, 2nd Hand brake assy You have got to love Land Rover Warrenty i do and Matfords they are good aswell If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
22nd Jan 2012 12:36pm |
Typo sorted If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
22nd Jan 2012 12:40pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5424 |
Reminds me of Triggers broom.
So there must be some bits that have done all those miles |
22nd Jan 2012 1:31pm |
Ahh yes the i have had this broom 20 years its on its 6th head and 8th handle but same broom !!! If everything is under control you are not going fast enough.
22nd Jan 2012 4:00pm |
How did you end up with the mileage on 200,000 and the trip on 500 spooky
22nd Jan 2012 4:23pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1806 |
That makes my 104,000 look quite meager now
But I'm looking good for a 100k more 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
24th Jan 2012 2:39pm |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 |
That makes my 20k in nearly three years very meagre, by that reckoning I'm good for another 30 odd years at least
Warranty bits so far; 2 sets of door seals fron and rear doors broken wiring loom to one rear door broken turbo pipe broken ignition barrel front and rear heated screens new clutch & DM flywheel |
24th Jan 2012 2:55pm |
