![]() | Home > Maintenance & Modifications > What do you use on your chassis? |
| RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2038
I appreciate this may only be for the die hard enthusiasts...
When I get mine I plan to prepare and paint the chassis with black satin Hammerite paint, a few coats, and then use Waxoyl afterwards, as I love a belt and braces approach to things. I used to use Waxoyl on my Series 3 many years ago and wondered if I am thinking about this in the right way: 1. Waxoyl clear for injecting into cavities, door bottoms, chassis rails etc http://www.halfords.com/webapp/wcs/stores/...yId_165594 2. Waxoyl Black for spraying onto exterior faces of chassis, crossmember, footwells etc http://www.halfords.com/webapp/wcs/stores/...zone=PDPz1 What I am not sure about is whether people use the following product in the same range on the chassis, as it appears you can only brush it on rather than spray it, which seems a total faff and ball-ache. (you can buy this in an aerosol but you'd need plenty of them and be bankrupt at the end) http://www.halfords.com/webapp/wcs/stores/...yId_165594 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
| JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412
Read this - sticky thread at the top of this board. It will tell you all you need to know ......
http://www.defender2.net/forum/topic10467.html John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
