![]() | Home > Maintenance & Modifications > Air Filter Test Reports |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
There are many air filter test reports done by manufacturers mainly aimed at the performance vehicle end of the market.
If you want some less biased reports to read which is aimed more at the 4x4 market have a read of these. Duramax AURLO Teaser AULRO Finally The first one is quite long and detailed, you can always skip down to the conclusion Make your own mind up (hopefully better informed) about performance filters and Defenders and how you use them. Brendan |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Ah ha, the Duramax test was the one I remember seeing ages ago. It's a shame that the pictures don't seem to work anymore, but the gist of it is that it doesn't show K&N filters in a particularly good light at all. Darren
| twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655
Mm, I've seen that before. Got to be careful of the scales on the bar charts.
Unsurprisingly the least restrictive filter also let the greatest amount of dirt through - if there was some way to change that I think filter makers might have done so by now.... |
