Home > Maintenance & Modifications > bush replacement advice
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
looking for advice from anyone who has replaced the large forward bushes on the trailing arms?
the reason, though the bushes seem to look healthy, I now have a gap between the large heavy washers and the bushes where the trailing arm connects with the chassie, I'm planning on remaining standard with the bushes as I hope to travel fare and wide and standard is easier to locate replacments,
so the real question is, can I just unbolt both ends of the trailing arm and replace the bushes without a press (not the axel end) and torque every think back up?
thanks for reading
Mark
Post #114994 13th Jan 2012 3:23pm
Do one arm at a time !!!!!!
The chassis bushes are really very easy, the axle bush can be done without a press, I'd be happy to advise on phone if you want to give us a call. QRZ 2e0vpf
Post #114998 13th Jan 2012 3:30pm
double cab happy
thanks Greeni, all I wanted was confermation that I'm not missing any steps that I then find when the vehical becomes undrivable,
and one side at a time sounds like the sort of advice that could save a real B**L ache
I was thinking of chocking all the wheels before I start as well, worth doing?
also thanks for the offer of the phone support offer, much appreciated
Mark
Post #115002 13th Jan 2012 3:48pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Before you change them ive just done mine and the new ones still have a gap between the rubber and the washer. I can take a pic if you want?
Post #115059 13th Jan 2012 6:38pm
double cab happy
Zinke, I had a number of issues with the rear suspention over the first couple of years, so I did notice the bushes at the front of the trailing arms can have a gap at the front lower and rear upper washer to bush when unloaded and at rest, now I have a gap top and bottom at the front or back depending on the load on the rear axel, if the vehical is parked with its nose up hill the gap is at the back of the chassie mount point and if down hill the reverse, its that movement that is the problem and making the noise.
thanks for the offer of the pics, I think that if this is an issue in two or three years again I'll be investing in cranked trailing arms to reduce this angle, but for now i'll just do the bushes now I know its doable,
mark
Post #115128 13th Jan 2012 8:20pm
Zinke
Well at least you know its a easy job, i took both sides off mine at the same time as i painted the arms at the same time and didnt have any problems.
Pete
Post #115238 14th Jan 2012 12:19am
shazzy90
dch i cannot help you as am i daft geordie builder,but i am pleased to see you are still around on the fourms ,i have never herd from you in a bit
Post #115244 14th Jan 2012 1:00am
double cab happy
cheers shaz,
still around, when not working Big Cry
how did your trip to the alps without a guide work out ?
Post #115744 15th Jan 2012 9:44pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Mark, did you manage to sort out the rear axle movement? was it the bushes in the end?
Jack
Post #115751 15th Jan 2012 9:55pm
double cab happy
still not fixed it yet Jack, after are summer outings where finished I did the waxoyl thing and the movment stopped until the last week, I think the waxoyl blistered and swelled the bushes just enough to stop the problem Cool
ordering the the bushes tomorrow,
hope your well.
Post #115755 15th Jan 2012 10:00pm
Landie Boy
ohh, well hopefully it finally stops it Smile im good thanks u? we will have to find an event to meet up at Smile
Jack
Post #115757 15th Jan 2012 10:05pm
double cab happy
all good here thanks, and yes that would be good
Mark
Post #115761 15th Jan 2012 10:07pm
