Home > Puma (Tdci) > bit of a diesel leak after filling then stopped.....? |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
See reply in technical forum
Brendan |
7th Jan 2012 2:01pm |
Buzz Member Since: 11 Oct 2011 Location: Inverness Posts: 235 |
Mine did this before I knew better. Don't brim it.
7th Jan 2012 4:45pm |
defender 1 Member Since: 19 Jul 2011 Location: stanley Posts: 12 |
land rover put the fuel tank breather and the filler neck breather on the same pipe when you fill right to the off the filler neck it runs out the breather till it is low enough the best thing to do is extend the breather pipe up to the wheel arch. sorted out a lot like that down here in the falklands
12th Jan 2012 2:47am |
ngarigo Member Since: 25 Nov 2011 Location: Alice Springs N.T. Posts: 81 |
thanks mate... i'll check it out... Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
'Wow...! What a ride! MY11 90 |
12th Jan 2012 2:53am |
