![]() | Home > Puma (Tdci) > ScanGuage won't reset engine light |
Kez Member Since: 11 Apr 2011 Location: UK Posts: 271 ![]() ![]() |
Have just had EGR valve replaced with a new one bought from local mail dealer, had t fitted by local garage as he's done a few bits before. Just got car back, go to reset engine light and it just keeps saying 'not ready'. So hit the force clear button, get the 'codes cleared' message. Turn on engine and its still there.
Listening to valve its doing it job as far as I can tell (you can hear the usual cleaning cycle) so really not sure whats going one ![]() |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
Lorryman100 its time to confess, your the head of software at LR. No way you could know all this shizzle otherwise.
How's the staff discount ? ![]() Pom |
@Pom No, afraid not. I just remembered it from when I read the instructions when I first got mine.
instructions
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
Yes that's right most items come with instructions, or where you wondering why all these companies give toy free coasters with every product ![]() 2011MY 110 XS USW Black |
Can you tell me where I can find the ones for my wife, looked everywhere and nothing works in a logical way!
Ok, its now a few days and still cant clear light - no faults showing, even doing a 'force clear' does nothing, local independent garage looked at it and they also could not see any faults - really don't want to have to resort to booking it in at Main Dealers but not sure what to do
I did the write up on some new remap files on Wednesday and cleared all fault codes from my Puma with the MSV, I then checked the scangauge today after getting an email notification of your post Kez, and it is still showing not ready.
![]() Click image to enlarge HTH Brian. |
The check engine light is the MIL, yes? That only illuminates when a tested DTC is logged. The scangauge does not show all tested dtc's as per the list on their website but the indie should have checked and cleared all DTC's after fitting the EGR valve. Do you know if he tried to do this? The fact the MIL stays Illuminated even after a new EGR has been fitted would have me checking the EGR plug as well as the adjacent MAP sensor incase anything was knocked when the EGR was being removed/fitted. Do you know what diagnostic gear the indie uses?
![]() Click image to enlarge Brian. |
Checked all connection and all fine, took it to another indy who has vastly superior diagnostic kit and right software for the Puma (my local chaps was a very basic unit that by his own confession was a bit old). Found one fault (maf sensor - again) and cleard it, light now out and all fine...except, when I check with Scanguage it still says not ready - how weird is that
It will show not ready again because you just had the maf fault cleared with diag gear. So it goes through the test cycle afresh.
