![]() | Home > Technical > Got the girls 'rated' SWL = 1 tonne |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
![]() ![]() Both looking good ![]() |
RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 693 ![]() ![]() ![]() |
Have they rated them as 1tonne for winching or for lifting? 130 Puma HCPU with an Artica 240LR Demountable Camper
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Lifting 130's have feeling's as well you know
Well done, hell of a difference between the ratings. Did they look at your chassis bolts first or just apply the test load and hope for the best!
I assume you lift pumps etc out of pits using a snatch block. 130 Puma HCPU with an Artica 240LR Demountable Camper |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
Qoute Mrs Greeni;
"THERE'S J-LO!" QRZ 2e0vpf |
They did check the mounts and bolts and then applied the load and stood well back ![]()
Yep ![]()
casher Member Since: 17 Sep 2010 Location: Glos Posts: 58 ![]() ![]() ![]() |
whats the gvw of them, must be pretty near 3.5 tonne? would be a git having to drive with a tacho all the time !
The grey one is standard appart from the winch so say around 2,200 and the blue one has had some extras fitted and she weighs in at 2,540.
We deal with water and sewage systems so we are exempt from the Taco requirements. We fall into "Vehicles used in connection with the sewerage, flood protection, water, gas and electricity services" 130's have feeling's as well you know ![]() |
Hope not ![]() ![]() |
