- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Romadog
Check small wire connection to starter motor. Remove and clean and replace. Had this on mine when only 500yds from home. Green flag man spent longer writing paperwork than the fix took ! Sounds like a bad connection / earth, but atleast try the starter wire as its easy to do.
27th Dec 2011 2:43pm |
