![]() | Home > Maintenance & Modifications > at 23:00 CET first Webasto (water) start-up!!!! |
No touch areas, the heater is positioned completely "over" the crossmember, the entreq fuel cooler guard is fixed under (see the nut insert on crossmember), and it protects very well the heater from splash and dirt....... ![]() Click image to enlarge ![]() Click image to enlarge Installed also the by-pass valve for do not decrease the original cabin heater efficiency she the heater is switched off ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 ![]() |
Nice job :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
I had a Webasto on a TD5 90 i had,,
Excellent bit of kit,, even had the remote control set up,, took 10 mins or so , was even connected to a hot water shower system ![]() Tried to justify the set up on the Puma,, but does not get the use to warrant the cost !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
The only cons is the lower position.... but I use my car for light off-rad The pros are the very short water pipes length so you have a very high heater efficiency and the accessibility for the future maintenance/checking operation. For the fuel tank accessibility I have done a "hole" directly on the rear floor and covered by a "strong" 3mm aluminium plate screwed with rivet nut inserts and foam gasket ![]() the ending results is similar to this one.... ![]() Click image to enlarge with this pickup ![]() Click image to enlarge ![]() Click image to enlarge For the kind of use that I do is the best compromise, I'm thinking about that a lot of months and finally........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License Last edited by dgardel on 24th Dec 2011 5:54pm. Edited 2 times in total |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2037 ![]() ![]() |
Got a FBH in the RR and my last one too. Great and useful bits of kit but by jimminy do they drain your battery if its not in A1 condition. Nice to be able to press the remote in the morning while taking an espresso before leaving in the cold and dark of winter.
![]() Luckily I just put a brand new battery in so I can use mine with impunity once more. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Thanks RRUK, I installed the remote too ![]() Click image to enlarge and "Webasto 1531" 7 days programmable timer (on the roof console) ![]() ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
daniele - you are the man with all the toys
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
Did you put your sun visors back in after fitting the roof console? Russell
2011MY 110 XS USW Black |
yes but you need to cut it 100mm. And I re-cover it (done by a upholsterer) with "eco"leather with the same colour of the roof console Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Good idea,
So do you find the console in the way at all, or does it not hang down to much? Russell 2011MY 110 XS USW Black |
no, no problem about that
:thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2011MY 110 XS USW Black |
Ditto.. and guess what.. LR has just changed the battery under warranty on mine,, after a call out one morning with it dead !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
what's a FBH ? |
