![]() | Home > Puma (Tdci) > Corrosion on the windscreen surround! |
My 110 had the same problem after two years.
Took the dealer quite a long time to sort it out. Bob |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Is this the drivers or passenger side and was it on a weld seem? Would be good to know if there is a common problem. A couple of spare windscreen frames is on the top of my Defender spares list to keep her going
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
I had this and some bulkhead corrosion on the inside of my 06 plate 110. I found the corrossion in Oct, I get my truck back from the dealers this week
![]() Every Defender I have had has suffered the same. ![]() |
common fault, ours was repaired earlier this year,Hunters use Chartwells bodyshop in Derby, they made a very good job of it. 2.4 90 XS
Anyone got any pics or can detail exactly where the corrosion areas are - it would be useful for us all, especially if ultimately new bulkheads/frames are need after warranty
![]() Last edited by Zagato on 19th Dec 2011 11:33am. Edited 1 time in total |
Passenger side in two places, top patch was on the front of the frame about two inches from the roof (just below the level of the windscreen top) and the second are was about 4 inches below this on the front/side angle. No welds or seams just plain rot ![]() Bob |
Thanks Bob
![]() ![]() Luckily a windscreen frame can be easily sorted but a bulkhead....that is not good, knowing which areas to keep an eye on would very useful... |
Both areas of corrosion started with the paint bubbling. At the same time as I noticed the windscreen frame problem I found the same on the offside passenger door.
All sorted under warranty. Bob |
Just reminded me to get my screen out and do a proper, permanent job on the frame and seal
![]() But shout it at them in German because life is also terrifying and confusing... |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6214 ![]() ![]() ![]() |
When I built my 110 3 years ago, i had all the bodypanels shot blasted back to bare metal, including the screen frame.
This was then sprayed by a proper body shop (they do all the bodywork repairs to my local dealership) and this frame is now bubbling/corroding at the bottom ![]() ![]() |
Red Desert Member Since: 23 Aug 2010 Location: Lake Constance Posts: 53 ![]() ![]() |
the one and only solution for this problem is: http://en.wikipedia.org/wiki/Anodizing |
