![]() | Home > Off Topic > Workshop/garage heating |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2965 ![]() ![]() |
What sort of heating do you guys use in your garage/workshop /shed low cost or otherwise
Buzz Member Since: 11 Oct 2011 Location: Inverness Posts: 235 ![]() ![]() |
Move around alot
IKke Member Since: 16 Aug 2008 Location: Brabant Posts: 117 ![]() ![]() ![]() |
Something like this
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
Those log burners made out of old gas cylinders are not bad.
Pom |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Low power drain caravan fan heater.
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
As said the gas bottle log burners are good and almost free to run. A few bits of wood and possibly a small amount of coal and they generate quite a lot of heat.
The diesel or kerosine ones are good but can get a bit wiffy in a small place. The gas ones are good but can get expensive to run of used a lot. Pete |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
There's a few ideas here:
http://www.aulro.com/afvb/general-chat/573...aters.html Cheers, Tim |
make friends with your local trucking firm for a limitless supply of used engine oil and get an oil burner.
Pom |
