Home > 4x4 Overlander > Cargo Bear
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
Cargo Bear
Hi Brendan,
Looking at these racks.
What is the model for a 90? the 1005mm is that 3 rails and infill panels, currently says out of stock?
Which system is the full length for a 90?
Also is there an option to have it powder coated to match the car?
Is there any Def2 discount on these?
Thanks
Chris
Post #770682 29th Apr 2019 2:50pm
williamthedog
Discount...... Brendan's just got up off the floor Rolling with laughter Rolling with laughter Rolling with laughter
Post #770687 29th Apr 2019 3:48pm
Sulisuli
He is likely to put you on the "rack" for mentioning the D word Rolling with laughter Rolling with laughter Rolling with laughter Being a sewage diver at least I know how deep the đź’© will be at work today.
2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #770692 29th Apr 2019 4:15pm
Snowy90
Well with Brexit it maybe the last one he sells in the uk! "Or will it happen!"
Ive never been one to shy away from asking anything!
Post #770697 29th Apr 2019 4:27pm
custom90steve
United Kingdom 2007 Defender 90 Puma 2.4 SW Stornoway Grey
Jeez, you’ve mentioned Brendan’s favourite subjects. Bow down Rolling with laughter
I think they look good, but how do you clean the roof?
I guess you just don’t I assume.
Unless there is panels that remove or some other access method. Diu Vivo Magna Britannia!
Watts Ă· Volts = Amps.
Amps X Volts = Watts
Post #770720 29th Apr 2019 6:25pm
Snowy90
Ha Ha Im sure he will crop up soon!
To be fair it was night mare cleaning with the old expedition rack so i generally didn't bother.Its so heavy to get on and off quickly it invariably stays on.
The Cargo Bear looks like they would stores easy when off or reduce to just bars for cleaning.
Still deciding but really like the look of them when on.
Post #770722 29th Apr 2019 6:37pm
leeds
Site Sponsor
Oi you lot, behave yourself otherwise it will be heads banged together time along with some force feeding of soap bars! Laughing
The Cargobear is a modular system with many options.
For a 90 there are several options
1) . 1005mm rack is 1 module and flat
2) 1890mm rack, 2 modules and flat
3) 1880mm rack, 2 modules flat 1005mm and sloping front section 875mm
4) . 2075mm rack, 3 modules, 2 x short extensions 1200mm plus front sloping section 875mm
Yes they are in stock.
Now if you want to clean the roof, can take off tread plates. It would be difficult to clean under the cross bars, but remove the clamps and just lift the rack up at an angle and put a spacer under a bar so can clean under the bars.
HTH
Brendan http://www.4x4overlander.com
Brendan's phone numbers 07929 604668/01422 243966 up to about 9pm
email address brendan@4x4overlander.com
Post #770752 29th Apr 2019 8:07pm
leeds
Site Sponsor
The Cargo bear is a popular roof rack. Below a photo of the amount of crossbars we have to keep in stock.
We have sent them to many different countries including UAE, Singapore etc. Air freight to those countries does not come exactly cheap Razz
They come black powder coated as standard. Now you could get tthem powder coated to a matching colour of your Defender but that would have to be done at your specialist local coaters.
Post #770995 30th Apr 2019 11:19pm
Site Copyright © 2006-2019 Futuranet Ltd & Martin Lewis
