![]() | Home > Technical > TD5 with no boost |
Intercooler blocked with gunge?
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 ![]() ![]() ![]() |
MAP sensor? Zero boost would mean the MAP, thats what my problem was anyway. Do you have a NanoCom? Double check no boost with that too? I replaced my MAP sensor and all was good
Ears of a Hawk Member Since: 19 Feb 2018 Location: Ayrshire Posts: 10 ![]() ![]() ![]() |
Thanks for replying. Inspected the intercooler - it was clear.
To give you some more background - The truck was going great - quickest its ever been then got an issue. It felt like it was running on 3/4 cylinders. Put it in to my mechanic and he checked the injector seals. Visually checked out ok but they were replaced anyway. When it came back - it drove OK apart from the no boost. There is no evidence of a engine problem . i.e. black, blue or white smoke etc Do you think it could be running on 4 cylinders? |
Hi Tank, I have ordered a NanoCom and I am waiting for it to turn up. However, I assumed that down stream of the turbo at higher revs I would have at least some pressure. When the truck is reving the Intercooler pipes can be squeezed easily. thanks
Try unplugging the maf and driving around for a bit and see if your power is back. Ray
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Check that the injectors have been replaced in the original cylinders when the seals were replaced. Unless they were removed one at a time they can get mixed up. This gives poor running.
Thanks for your posts. I will try the MAP disconnect but my only concern is that it was replaced recently. But you never know. Also, I would like to think that my mechanic (who has a lot experience with land rovers) wouldn't mix up the injectors - but I suppose everybody can have an off day. thanks
It's the MAF you need to unplug not the MAP
![]() My build thread http://www.defender2.net/forum/topic17615.html |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 ![]() ![]() ![]() |
Anything to do with clutch switch?
Sorry, just a typo. It was the MAF sensor that was replaced
If you have no boost then it is your MAP sensor on the fuel intake, not the MAF sensor on the air intake side. If the MAP is dead or even disconnected, then you'll get no boost and no power. That was the problem with mine. Check that the mechanic hasnt disconnected the MAP sensor or bent the pins putting the plug back on.
Tank |
Reading your post again I bet the MAP sensor has not been plugged back in or pins are bent!
Can any Defender owners with high mileage help me out. I took off the Exhaust manifold heat shield and inspected for warped manifold. No visible signs. It didn't show up anything using soapy water spray.
Link up my new nanocom and checked Turbo pressure. This shows that the turbo pressure gets up to a maximum of 0.15 bar at over 2500rpm - it doesn't have enough to actuate the wastegate. Is there anyone out there who has had an issue like this - perhaps turbo related. Any additional tests I could perform before tearing down the Turbo. thanks |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2216 ![]() ![]() ![]() |
Where is your boost gauge tapped in?
100% all the boost hoses are intact and not leaking? Inlet manifold gasket is in place and not leaking? |
