Home > Technical > Reverse Light not working
Bluest
My reverse light doesn't work, bulb is fine and there is 12v at the terminals so I'm very puzzled. Any suggestions? 2007 110 TDCi Station Wagon XS
Post #577313 12th Nov 2016 3:57pm
Have you checked Earth continuity.
Most likely the switch, usually start this time of year when it's colder.
Replace and hopefully all sorted. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #577320 12th Nov 2016 4:37pm
Bluest
If it was either of those things would I still be measuring 12v in the bulb holder? 2007 110 TDCi Station Wagon XS
Post #577321 12th Nov 2016 4:39pm
Martin
Site Admin
As mentioned a few days ago in another thread, I have seen a failed reverse light switch which showed 12V at the lamp socket but which dropped to 0V when the lamp was plugged in.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #577329 12th Nov 2016 4:55pm
^^^^ Sounds about right, the reverse switch is earth switched too I believe.
As soon as it has current draw on it it won't work.
Interestingly, I found an LED light would, Incandescent wouldn't.
Maybe try it if you wanted to upgrade, unless you already are using LED?
The thing is if your measuring voltage at both pins, that means it depends also on the earth in question and not it's continuity or capability of carrying current.
They are known to be problematic, I've had it myself.
I never touched my switch I found fitting an LED light solved the issue. ____\We|Will|Win/___
Post #577332 12th Nov 2016 5:04pm
Mo Murphy
If its the round type of reversing light, the usual culprit is corroded pins in the connectors requiring a new plug and bulb holder.
50 Shades of Pennine Grey
Post #577334 12th Nov 2016 5:10pm
Martin
Site Admin
It's switched on the 12V path.
Swapping to an LED isn't really a fix for a dicky reverse light. Although it may light it will not be at full brightness.
The switch is cheap just a bit tricky to get to. A long straight spanner (22mm?) from underneath does the trick.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #577335 12th Nov 2016 5:11pm
Chopperone
Slight hijack
I have the same problem.....
My new to me 2007 90.
I am currently changing all lights to LED & I started with the rear lights.
To be honest I don't know if the reversing light was working or not before I started the job.
Anyway it doesn't now.
I have 12v at the plug but it won't light an led or the old light or the old fog light.It won't even light my test light either using
A separate earth or the earth in the plug.
So I assume this means the switch is faulty......OR is it something else?
Is it fairly obvious where the switch is?
Who makes the best replacement switch?
TIA
Guy
Post #578355 17th Nov 2016 4:16am
Martin
Site Admin
Switch part number is LR077773
The genuine LR offering is not a bad price - £10 inc VAT from duckworthparts (send a PM)
Pattern ones are about £8  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #578405 17th Nov 2016 10:16am
Bluest
Just an update. Fixed today with a new reverse light switch on the gearbox. A hateful job when you have big sausage fingers like me. 2007 110 TDCi Station Wagon XS
Post #582760 4th Dec 2016 10:04pm
How did you get at it from in the end? ____\We|Will|Win/___
Post #582764 4th Dec 2016 10:09pm
Bluest
A combination of over and under.
I took the panel out under the cubby box. From there I could disconnect it (just), loosen it with a 22mm spanner, and unscrew the old one. But I couldn't articulate my hand enough to put the new one back in from there, so I did that from underneath. 2007 110 TDCi Station Wagon XS
Post #582767 4th Dec 2016 10:12pm
Shorty53
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
My reversing light was flickering and intermittent. Replaced the gear box switch today, but a hell of a job. Researched this forum for advice. A dealer technician said that the L/R procedure is to remove the gear stick. Followed Bluest procedure and removed the cubby box and access plate. Scratched knuckles and a 22mm ratchet spanner just about managed to replace the switch. Impressed with those who replaced the switch from below with no disruption.
Post #587117 23rd Dec 2016 12:29am
