![]() | Home > Maintenance & Modifications > Leisure Battery |
Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223 ![]() ![]() |
Thanks Brendan, Good point.
Do you sell battery monitors? Think I saw a split charge system on your site a few weeks ago when I was looking at the Nolden lights. James |
the lower you take it the fewer cycles you'll get. "Leisure" batteries are not proper deep cycle batteries and still don't like deep discharge. Leaving your fridge cutting out at high voltages will prolong your battery's life at the expense of a a bit of run time at the start of the battery's life. Towards the end of it's life in a few years, you'll probably get longer runtimes by sacrificing them now. Depends where your priorities are really. |
The OP mentioned an Optima yellow top which is a combined starter/deep cycle or starter/leisure battery whereas the Optima red top is a starter battery.
For a 4x4 running a dual battery system it is a good idea for the second battery to be a combined starter/leisure so you are able to start the engine from the second battery if need be. Used to run dual yellow tops until one failed suddenly The two 110's were equipped with dual Odyssey batteries. The Odyssey 1500 is roughly the same size as the Yellowtop however with a larger capacity and CCA. Odyssey are combined starter/leisure batteries. 90XS what dual charging system are you running. The IBS system is good. Cheap dual battery monitors are available on eBay or we could probably source a National Luna dual battery monitor for you. Brendan |
