![]() | Home > Maintenance & Modifications > Leisure Battery |
once a battery starts dropping below 12.6v resting no load its on its way out
battery at 12v =25% left 12.2v =50% charge left so at 12.1v its knackered really but might be worth giving it a good charge on mains charger then leave for few hours and checking resting voltage then just to make sure |
Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223 ![]() ![]() |
Thanks Munch - have done that as thought would check - had it charging overnight and as soon as disconnected it dropped to 12V again.
Appreciate the response seems to confirm my suspicions. So what battery to replace with? Need one of similar size to fit under passenger seat - looking at another Optima but also just came across a virtue AGM battery and is a third of the price? Normally would buy expensive as cheap normally means buy twice - but are Varta any good? Thanks James |
Varta are one of the big makers , alot of cars come new with varta
Just had a look at them - they are lead acid batteries - probably not ideal for a 4x4?
Why is a lead acid not for a 4x4 ?
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5130 ![]() ![]() ![]() |
Wondered that myself, always had lead acid batteries as leisure batteries. Cause technology has changed, but, not that much! But perhaps there is now something different, I do not know about, after all there is that thing called the gadget show on channel four or is five or some other channel I do not watch
![]() http://www.youtube.com/user/conwy1 |
Maybe an incorrect assumption from me that a lead acid battery wouldn't be as good as a gel battery for 4x4 use but the more I think of it if the battery is working upside down then I've got bigger problems!!
Is there any advantage to a gel or agm battery over lead acid? Thanks! James |
Waeco are a decent brand. I would suggest you have a read of the instruction manual.
Yes chances are your battery is on its way out
Also
At 12.1 volts battery should run fridge unless you have losses in wiring etc . Or that as soon as fridge load is put onto battery the battery voltage drops below the setting on the battery protection. So check battery and the wiring to fridge as well. Brendan |
They all basically lead acid
standard lead acid are flooded cells , normally cheaper , as fitted to 99% of cars agm are where the acid is soaked in to a glass matt to help make them spill proof gel is acid in gel form so more spill proof Really all depends on what space you got, what output you want , and what vehicle is used for etc etc |
Thanks Brendan, didn't realise my fridge had a high/medium/low setting! Will have a look at it, have measured at the output which is a 12v socket directly from fuse box directly attached to leisure battery and had 11.7v so this would seem to suggest it's set to high.
Either way though seems the battery isn't holding charge that it should as there is no load when I'm measuring the drop to 12v. James |
You do pay a premium for AGM batteries and I'm not convinced they're any better for most purposes.
We bought a second hand tractor which came with a pretty new Optima (same size as people put in Defenders) and that was one of the most pathetic and short lived batteries we've ever had in a tractor, it was forever needing jump starting in winter. Now been replaced with a proper tractor battery (of about the same capacity but lower CCA as you put in a Defender) and it's been fine since. Have a read of this and make up your own mind: http://www.atlanticmotorhomeservices.co.uk/battery-technology.php |
I always stick with lead acid as never found any of the so called longer lasting premiun batterys any better all seen to last about 5 yrs
use exide,varta,bosch etc only thing i would do is use a gel battery in side cabin area during to gassing when charging , alot of batterys are called sealed but still have pressure regulating valves for gassing if overcharged so still possible for then to vent explosive gases ive seen a few batterys explode, not a good thing to be near! |
Thanks for all the replies.
Have just been out with the multimeter and checked the batteries. Primary Battery (Odyssey PC1500) is at 13,1V with engine off - goes to 14.6V with engine on. Second Leisure battery is at 12.15V and goes to 14.55V when engine turned on. Ive driven 200 or so miles today so should have got a decent charge. When the engine is turned off, second battery immediately dropped to 13.3V and during the next minute dropped to 13V holding the multi meter against the terminals. Checked it again in 5 minutes and down to 12.4V, 5 minutes later down to 12.25V, 5 minutes again and down to 12.18V. So looks like battery is not holding charge and is kaput!! Now replacement battery - replacement Optima yellow top, has lasted 5 years and doesn't need venting - all wiring will fit and will go straight into battery compartment BUT is £160 cheapest place found. Or replace with Varta Deep Cycle - I can find one that is similar dimensions, will need wiring slightly changed but will need venting... Devon 4x4 battery tray covers the vent hole that I had for the original OE battery so will need to find a new exit although quick search and found a decent looking one for £86. Choices choices!! James |
@Brendan - thanks for the Waeco detail!! I didn't relaise my fridge had a High/Med/Low setting as is controlled by the menu. Its set to high so was cutting out at 11.7V as you say!!!
Once get battery sorted will drop this down to Low as it runs from a leisure battery so doesn't matter!!! Thanks James |
