Home > Td5 > Bonnet stay plastic clip! (How to)
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
Could anyone teach me how to install this bonnet plastic clip?
does it need screw at the bottom? my was broke and don't know how it was! Question Rolling Eyes
Post #422018 8th May 2015 1:45pm
bob neville
Snap the bottom off, this goes under the metal plate, and then the other part pushes into it.
http://www.defender2.net/forum/topic34498.html?view=previous
2013 Defender 90 CSW - sold
Post #422023 8th May 2015 2:15pm
RF3777
Hi, Bob
I'm not sure if I'm getting it right, do you mean break it into2 pieces ...
Then one piece go under the metal plate?
Post #422024 8th May 2015 2:21pm
bob neville
Thats right.
Split into two along the indented line about a third of the way along from the left hand side. The smaller bit ( the LH bit) goes under the plate with the longer bit ( the bit on the very left of the image) facing up. The RH piece with the stay clip then pushes into this from above. The metal plate will then be in between the two pieces.
Post #422030 8th May 2015 2:39pm
RF3777
Hi, Bob
Understood, thanks for the clear instruction!
Cheers Thumbs Up
Post #422033 8th May 2015 2:50pm
excossack
I am not sure I did mine that way as when I put it together like that when I pulled the bonnet stay out of the clip, it pull the clip clean out and then I dropped the other bit.
I think (from memory) I did it by snapping off the bottom bit (LH) and then popping that through the hole from above and then inserting the clip section (RH) and its still there now. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #422035 8th May 2015 2:53pm
excossack
If I think on tonight, I will take a pic for you 1999 Defender TD5 110
Regards
John M0VAZ
Post #422036 8th May 2015 2:54pm
bob neville
Now you mention it John ...... !
I think you could be correct. I believe the official way is the one I detailed and that was how the original clip was on my TD5 so I replaced as it was but now you have mentioned it I may also have put the smaller bit in from the top and pushed the clip into it.
I will also have to check tonight.
I think the main thing he was missing was the bit about splitting the fixing into two.
RF3777, if you follow my method of fixing and you find the lower (smaller part) keeps dropping off the main part of the clip try putting it in from the top with the longer bit facing down and then push the clip into it.
Post #422051 8th May 2015 3:51pm
Martin
Site Admin
I've just fitted a similar brake line clip (into the chassis).
This fitted by breaking into two pieces, putting the lower part in the hole then pushing the top clip part home.
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #422078 8th May 2015 7:03pm
RF3777
Thanks everyone!
Thumbs Up
Post #422164 9th May 2015 9:35am
nitram17
Re: Bonnet stay plastic clip! (How to)
e]oooops i hate computers!
Post #422179 9th May 2015 10:24am
nitram17
This?
Post #422180 9th May 2015 10:25am
RF3777
YES!
I just did...but I'm sure this plastic clip will broke again soon! Evil or Very Mad
Post #422185 9th May 2015 10:30am
GoatRider
United Kingdom 2002 Defender 90 Td5 HT Bonatti Grey
I also wondered about this.
In the end I pulled out the snapped catch with mole grips.
Then I pushed the new one in so the lower collar was home and flush.
Then I got a reasonably thick screwdriver and rested the shaft across the 'cup'.
Then just pushed down.
It slotted down easily and I think there must be a rivet effect underneath as it was tight.
Much easier than expected.
Post #852537 28th Aug 2020 8:37am
I've broken mine umpteen times.... I ususally just place the whole thing into the mounting hole, then with a decent sized flat blade screwdriver, place it in the "clip" (where the bonnet stay would go) and with a sharp tap of a hammer the whole lot will pop down into place.
Post #853263 31st Aug 2020 6:26am
