Home > Puma (Tdci) > Foglight switch for rear wok light
Page 2 of 2 <12
Martin
Site Admin
A permanent 12V supply for pin 1 out could be picked up from the hazard switch - purple/brown pin 2.
The output from pin 4 could then go off to the relay pin 86. Relay pin 85 would need earthing, and the "feedback" from the output of the relay would not need to go back to the switch.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #398458 13th Feb 2015 2:38pm
x-isle
Yep, should be good as stealing a small amount from the 10amp Hazard just for the relay power should be fine. Thumbs Up
In fact, it simplifies it all doing it this way. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #398461 13th Feb 2015 2:45pm
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
I assume this is with the heated seat switch?
x-isle wrote:
aha, and there you go.
Just need to move the switch to the other side of the relay, feeding 86
Post #398463 13th Feb 2015 2:55pm
x-isle
Yes, and probably the same with the rear screen heater switch too. Craig Rogers
2007 Puma 110 XS
Post #398464 13th Feb 2015 2:57pm
Marius
I managed to source a Aux spotlight switch for the rear work lamp. The one with the beam and number two on the front. So correct me if I'm wrong. The circuit remains the same as the one I changed but the pins will now be.
1 relay 85
2 dash illumination
3 unused
4 earth
5 as per drawing to 87
Is this correct?
Post #398929 15th Feb 2015 6:00am
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
What switch cover styles are available to fit in the puma dash?
I am thinking of doing this myself and wonder what is the best "style" front to use to indicate its a rear work light.
Thanks Darren
Post #398948 15th Feb 2015 9:39am
x-isle
1 relay 85
2 dash illumination
3 unused
4 earth
Is this correct?
Yes, exactly correct. Thumbs Up
You can use 3 or 4 for the earth as they are both the same. Craig Rogers
2007 Puma 110 XS
Post #398959 15th Feb 2015 10:19am
Page 2 of 2 <12
