Home > Puma (Tdci) > Electrical Question
IanW
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
Electrical Question
We've just changed touring caravans, and the replacement has LED lights. They work perfectly but when the indicators are switched on the trailer light on the dash doesn't flash as it did previously with conventional bulbs in the old caravan. Do I need an extra electrical bit in the circuit to make the repeater do its stuff, please? Suggestions would be welcome. Also are there any recommended tow bar fitters/auto electricians in the general Bristol area who could convert the 12S and 12N sockets on the 110 to a 13 pin set up?
Thanks in anticipation, Ian One wife - livid
Post #335619 4th Jun 2014 9:10am
martinfiattech
Does your new caravan have resistive led`s. ( this does depend on how the system is set up )
Modern vehicles that have led lights fitted need resistive leds as the internal resistance of a normal light bulb is a lot higher than a led, so the car may not be able to sense the extra load.
I see this problem a lot at work with motorhomes as the owners like to fit led lights, but the vehicles body computer needs to see a resistance value in the circuit so it can.
1. test the circuit.
2. figure out if the bulbs working or not.
So if the resistive value is to low the BCM thinks the bulb is blown or there a open circuit in the system.
As for the 12s/n cables you can get a special set of leads so it joins it all together might be cheaper than getting it rewired. Excuse the spelling I`am better with spanners and wires.
Post #335822 4th Jun 2014 10:06pm
IanW
Thanks Martin. Made a few calls locally with widely varying responses from auto electricians, but the most informed response paralleled your comments. The wiring options seem to be taking a 13 core cable back to source on the 110, or splicing the two existing cables into a 13 pin socket. As to detecting the LED indicators the local auto electrics company seem to think they can add something to the circuit which will detect the extra load, if that makes sense. My technical electrical knowledge nil, ax you probably guessed. With more caravans being LED equipped I guess this question will crop up again. Thanks again, Ian One wife - livid
Post #335832 4th Jun 2014 10:17pm
Porny
Site Sponsor
A Defender isn't that advanced to use a BCM lol...
If you don't want to make any wiring mods...
You could use one of these:
http://www.mobilecentre.co.uk/index.php?ma...1a0040dc44
Also, with regards to converting to a 13 pin socket... Save all the hassle and just fit the geniune kit - LR005919
This will - if wanted - fit into the recess (often refereed to as the PTO hole) on your rear cross-member with the use of 3 riv nuts. Is plug and play...
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #335989 5th Jun 2014 6:51pm
What Defender indicator relay are you running?
Post #335991 5th Jun 2014 6:57pm
IanW
Hi Steve
Appears to be the top left one in the main fuse box, marked if I'm reading the mirror image right as ELR HEW and 301 102 31, if that makes sense.
Post #336143 6th Jun 2014 10:35am
Is it a standard relay I.e. From the factory or LED biased such as RDX or Wipac? I'm guessing factory standard.
The RDX will let you use the trailer light but you'll need resistors on the trailer / caravan.
There's not really another way around that for LED's and trailer light unless you go down fitting a buzzer route which is no longer OE and you will loose the trailer light permanently.
Depends what resistance the LED's on the trailer are too, it maybe possible with fine relay adjustment to still get the light to come up.
It's something that I'm thinking of exploring myself one day.
Post #336152 6th Jun 2014 10:52am
IanW
I'll let you know how I get on with it Steve. Response awaited from LR, but will probably need to source a part from Sargent Electrics who supply the caravan electrics
Post #336173 6th Jun 2014 1:01pm
