![]() | Home > Puma (Tdci) > Work Lamp |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 ![]() ![]() |
Do I need a second relay? Should I get a fuse box? Ideas?
Thanks[/quote] The Purple wire is fused at 20A, the wire from the fuse box to the towing socket pickup connector is 3.0mm2, the spur to C1692 is 2.5mm2 .[/quote] Not sure I understand the respone |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
Sorry, I should have made that a bit clearer ![]() What I meant by my reply was that the wire gauge and fuse are large enough to support an accessory socket (10A max) and a worklight (typically - 55w, which is just under 5A) without using a relay or an additional fusebox. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
thanks I think I will wire the accessory socket direct and the work light on the relay.
are the terminations for these also behind the offside rear speaker panel? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17947 ![]() ![]() ![]() |
Yes. |
