Home > Maintenance & Modifications > Defender led lighting
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
Hi everyone, i've managed to get NAS style led light units in either red / yellow or clear as in the 60th Defender, so really just looking for any ones views on these -
hopfully the pic will work
https://s3-eu-west-2.amazonaws.com/i.hubnu....jpg[/img]
Post #7236 13th Feb 2009 4:41pm
nicks
no, pic doesn't work - how do i get them on here?
Post #7237 13th Feb 2009 4:42pm
110SEB
You need to press the IMG button once before you paste in the pic link and once after or copy the IMG code from photobucket and it'll put in the right prefix and suffix for you ([img] then [/img])
Here you go...
Post #7239 13th Feb 2009 5:10pm
110SEB
Ah. Now that, i can't help with. Good luck and have another go.
Post #7240 13th Feb 2009 5:11pm
nicks
thanks for your help
here we go
Post #7242 13th Feb 2009 5:52pm
Laurie
You'll probably have to replace your flasher relay due to the change in current.
Post #7243 13th Feb 2009 6:29pm
nicks
got some of these...
Post #7244 13th Feb 2009 6:38pm
werdan
Australia 2003 Defender 110 Td5 SW Bonatti Grey
What does the new relay do for you? I would have though the LED light units would have been less wattage than the incandescent units they were replacing.
Post #7247 13th Feb 2009 11:11pm
Laurie
The relay is current operated.
Less current means an ordinary one won't work Rolling Eyes
Post #7253 14th Feb 2009 12:07am
werdan
Thanks.
Post #7256 14th Feb 2009 2:47am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Nicks
where did you get the lights and relay from?
Post #7265 14th Feb 2009 11:16am
nicks
Hi Cobs
i've got a load from the manufacturer that makes the clear ones for Land Rovers 60th defender. I personally prefer the red and yellow. We originally bought them to make waterproof boat trailers, then when they turned up it dawned on me what else I could fit them on....my Defender.
Post #7267 14th Feb 2009 12:23pm
nicks
use with the plinths
clear 60th version
Post #7268 14th Feb 2009 12:26pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Nicks, do these fit the same holes as the standard lamp units or are they slightly wider diameter and thus require re-drilling? 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #7271 14th Feb 2009 12:51pm
nicks
dm_td5
you can drill new holes, but i'm going to re drill the plinths to use the existing holes.
Post #7275 14th Feb 2009 4:55pm
