Home > Puma (Tdci) > Clutch Pedal Biting HIGH |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 240 |
As far as I know the you will have to access the pedal box.. In there you will find a threaded rod running through a trunion and there are adjustment nuts either side of the trunion which will adjust pedal height and pedal free movement..
My manual mentions a bolt accesssble on the front face of the pedal box been used to alter pedal height but on mine that is definate ly not the case.. That bolt only limits the downward stroke of the pedal.. There are most probably differences in pedal boxes so you would have to check, or someone may know when the changes took place👍 |
27th Mar 2024 9:07am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3210 |
1. As Andy stated, also check that the master cylinder push rod is ‘free’ when the clutch pedal is released. Thats to ensure that the non return valve is working properly and no residual hydraulic pressure remains in the lines.
2. If it is Td5, check that the fuel pressure regulator is not leaking. That can cause the clutch to slip. 3. Could be a worn out friction plate where it has become too thin - so not enough clamping by the pressure plate. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
27th Mar 2024 12:10pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19579 |
As Andy63 mentioned, it’s fairly easy to do, just make sure it’s not loose once you’re finished adjusting.
There is a pedal height specified in the WSM, I expect you may be able to find it on here somewhere if you search for it. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
27th Mar 2024 7:51pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 795 |
[quote="Dinnu"]1. As Andy stated, also check that the master cylinder push rod is ‘free’ when the clutch pedal is released. Thats to ensure that the non return valve is working properly and no residual hydraulic pressure remains in the lines.
Technically it's not a non return valve but just an open path between the reservoir and the slave cylinder through the master cylinder so that the slave cylinder is free moving and resetting for clutch wear. |
28th Mar 2024 5:43am |
