Home > Puma (Tdci) > (Hopefully) Simple Heater/Aircon Trim Question |
Keyser Soze Member Since: 15 Mar 2024 Location: Valais Posts: 6 |
I have the entire interior apart and am replacing all the hardware plus any plastic I can swap to aluminium. One little thing has me stumped and I am trying not to break the backing plastic.
Click image to enlarge These two plastic bits in black for the AC level and the exterior/interior recirculation, what's the trick in getting them off? Don't see clear clips, they don't pop off on pull, and I can't see any adhesive. I don't want to damage the green plastic below. Any easy tricks? Help! |
21st Mar 2024 9:04pm |
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 154 |
Mine just fell off when I took the dash apart, if it helps, the green plastic is part of the slider.
25th Mar 2024 11:37pm |
Thanks for the help, I just had to take a small screwdriver and break the edges. You have to be careful as the sliders are the green glass (if you're changing them to aluminium like I was - you'd need to find unbroken bits).
Thanks for the help! |
28th Mar 2024 9:44pm |
