Home > Puma (Tdci) > Seat base anchorage
Sam smith
United Kingdom 2009 Defender 110 Puma 2.4 HT Epsom Green
Seat base anchorage
Hi does anyone happen to have any photos of how this is supposed to look for the “seat base anchorage” as I can’t seem to picture how it is supposed to go.
Post #1025978 25th Feb 2024 11:45pm
NickMc
No 1. Under the front lip of the tub for seat belt stalk mounts, depends on model though
No 2 is sandwiched with one and goes down to the tall tub support bracket on a 110 hardtop chassis.
No 11 is the bit that goes on the rear edge of the Seatbox and sill for the end of the belts again depending on model.
Post #1026102 27th Feb 2024 2:16am
Sam smith
Hi thanks for replying to my post, just to check the no2 goes to these bits to the bits i have circled?
this diagram was the setup it had but it also had the no2 in the parts with it when i got it. is it possible to have both or only 1 part from the previous diagram and not all of them?
The only plugs missing from the front tub lip were for the seat belt to tub mount that ive circled in this diagram. as the seat belt reciever stalks are perpendicular to the tub lip and further into the seat box on no3, any ideas there?
/ does it need to have the anchorage from the previous diagram if i have this setup?
cheers
Post #1026238 28th Feb 2024 10:34am
Sam smith
Post #1026240 28th Feb 2024 10:36am
Linds Hanson
The brackets you have circled bolt through the vertical toe panel in the centre footwell of a station wagon
Post #1026242 28th Feb 2024 11:53am
Sam smith
hi this is for a 110 hardtop not sw
Post #1026243 28th Feb 2024 11:56am
