Home > Faults & Fixes (L663) > P0401 - EGR flow insufficient |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
Is that one of these two?
Click image to enlarge |
7th Jan 2024 3:06pm |
Or perhaps this one, sensor circled in red and the tube in blue?
7th Jan 2024 3:29pm |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 131 |
hi Retroanaconda, were you able to solve the problem? thanks for sharing.
Marco |
14th Feb 2024 7:29am |
I’ll let you know at the weekend, picking the car up on Saturday evening.
15th Feb 2024 10:39pm |
Definitely not solved - problem now back as bad as before and P0401 fault also now showing along with the warning light again.
Back to the dealer we go |
26th Feb 2024 6:34pm |
91dm Member Since: 26 Feb 2024 Location: Ireland Posts: 10 |
I have this exact issue for the last four weeks.
Same P0401 code and hesitation/judder at 1200-1500rpm, worse on inclines. It's better driven in S keeping the revs up. Is it a cracked pipe / leak off somewhere? I think the EGR code is misleading LR? Mine is also going in for a new EGR. Good to know I'm not alone with this issue, first issue I've had. Thanks! |
26th Feb 2024 10:11pm |
The dealer replaced the exhaust manifold pressure sensor and its feed tube on Friday, and having done 300 miles home I am hopeful that it has been sorted. Fingers crossed it stays sorted.
14th Apr 2024 9:33am |
great 90dv!!!, he found the problem straight away, however I'm glad you solved the problem. thanks for sharing.
Marco |
15th Apr 2024 10:02am |
That's good to hear.
Mine is going in this Friday for a full EGR valve and cooler change for P0401 code. |
15th Apr 2024 8:10pm |
Retroanaconda, has your fault come back since?
New EGR assembly didn't make any difference to mine. |
24th Apr 2024 7:57pm |
No, not yet - seems good so far.
25th Apr 2024 9:35am |
Thanks Retroanaconda, hopefully can get to the bottom of my issue.
25th Apr 2024 10:06am |
