Home > Maintenance & Modifications > Easy fix to stop your handles seizing in the cold
Stacey007
Hello
I generally park my car under a car port at the side of the house so in cold weather its sheltered. However the wind must pass through and in particularly cold weather the handles freeze shut.
So this is a quick / cheap / easy fix.
I've cut up a few more and put them on the other cars in the drive Smile
Post #1016830 30th Nov 2023 1:54pm
Co1
Given them a good spray in the barrel with Abus lock lubricant. That used to keep mine from freezing up as it coats the internal with a dry silicone lubricant.
Post #1016832 30th Nov 2023 2:03pm
Screbble
Both good ideas Thumbs Up Thumbs Up
Post #1016891 30th Nov 2023 8:25pm
geobloke
Love a simple idea Thumbs Up
I confess to be fond of a good squirt of silicone spray around the push button and smeared onto the rubber door seals. Works a treat when icy conditions are forecast.
Post #1016892 30th Nov 2023 8:37pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Or just move to the south of Spain. Never had one freeze up down here Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #1016894 30th Nov 2023 8:44pm
