Home > Puma (Tdci) > Vacuum Pump oil leak Puma 2.4 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2266 |
Sometimes its bottom gasket fails and oil leaks. Puma 110" SW
24th Nov 2023 2:47pm |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 228 |
I’ve had 2 gaskets go and 1 pump fail. When the pump failed oil was around the pump spindle, with gaskets the oil was below the pump and gasket 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
25th Nov 2023 7:57pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16892 |
The gaskets leak if you overtighten the securing bolts. For once it is worth (a) using a genuine Ford gasket, and (b) using a teeny-weeny torque wrench.
25th Nov 2023 9:32pm |
SilverPuma Member Since: 27 Oct 2023 Location: Devon Posts: 24 |
I had oil film regularly around the inlet manifold, hp fuel pump etc. And it turned out to be the vacuum pump. As the viscous fan for the rad has quite a bit of power is spreads the leak into a fine mist on surrounding parts and pipes making it awkward to spot the cause. The gasket is a significant almost sandwich plate with rubber seal inset. Definitely worth paying up a bit for a decent one. 2010 2.4 TDCI Puma Defender 90
26th Nov 2023 2:51pm |
WPRO18 Member Since: 13 Feb 2023 Location: London Posts: 63 |
Thanks all, this should be getting sorted in the next few weeks. Car has been idle, as I've been away. I did take it out today and it seems to create the same level of 'mess' and not gotten worse.
Having said that, I was moving the car out today, after it sitting for quite a few weeks I'd taken it for a run and halfway through a motorway run it has flicked on the engine management light. Car runs fine (pulls well and without the light, you'd not know anything was up) , but wondering if that vac pump could cause the dash light to come on / stay on? |
26th Dec 2023 5:27pm |
