Home > Puma (Tdci) > Interior Light - weird fault |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
My wife has reported a rather strange fault in the Puma today. As she drove along the interior light at the front would come on then fade out and a while later repeat this and so on randomly. I took the car for a drive after work and found the same thing. It doesn't do it when the light is set to OFF or ON, only when on door setting.
Never heard of this happening before so I'm rather confused. The only thing I can think of is an issue with one of the door switches. I had to realign all 4 doors last weekend to install the checker plate, so perhaps one of the doors isn't pushing the switch in sufficiently. Anyone else come across this fault? 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
6th Feb 2009 7:26am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I had something similar a year ago - the interior light would suddenly come on when I was driving and then fade out.
I think I gave it a thump and ignored it. I've not seen it happen since. I could only assume that there was a dodgy earth somewhere. The door switches are fairly simple things and there's not much logic in the system. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
6th Feb 2009 10:40am |
Just an update.
The latest quirk is that when I get out - down the shops - and press the lock button on the fob, the horns sound for a miss-lock. It's very LOUD:eek: Anyway, I've now traced the fault to the driver's door. If I hold the switch in everything is fine. I've now unscrewed and jiggled the switch, put it back and all seems OK for now. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
7th Feb 2009 2:53am |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 |
Same issue with the interior light, went throw deep puddle and it came on and went off a couple of times! Maybe the truck was shocked to see all the snow melt. One to keep the dealer busy when it goes in to have ABS sensors sorted out.
7th Feb 2009 10:03am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
I was going to say the door switch
The lights run through the Alarm ECU (thats how you get them on and off when you open/close the doors) there are also some good settings in there (or are on the older discos) The switch is an earth type Mike |
7th Feb 2009 6:05pm |
Maybe I just had some water get past the door seal and got into the switch
7th Feb 2009 7:09pm |
