Home > Maintenance & Modifications > Cautionary tale of R-clips |
MercianRover Member Since: 07 Apr 2022 Location: Culworth Posts: 124 |
Photographs as evidence and ask the workshop to explain themselves?
Maybe a chat with trading standards too? |
12th Jul 2023 4:51pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16879 |
I have seen kits supplied with R-clips instead of split pins, and I imagine whoever fitted them just used what was supplied. The issue is more likely to be with the supplier/manufacturer than fitter.
I imagine that someone has decided that split pins are too complicated for the typical modern technician. |
12th Jul 2023 6:31pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6037 |
I once had a genuine set of LR pins (military stock IIRC from when I was wearing green) and they had R clips.
Having said that, I used these for numerous years and never had any issues with them. Maybe I was just lucky, or your R clips were sh!te quality. Worth contacting the garage you used though. |
12th Jul 2023 6:38pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2550 |
R clips were used from the factory on some vehicles - there’s nothing wrong with them per se. The clips themselves should see no load and just retain the pins which carry the pads.
Probably cheap rubbish parts as above, or they just forgot to fit them. |
12th Jul 2023 6:47pm |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 149 |
The R-clips didn't look great, but as you say, they really have no load to take in this situation. My money is on that one never having been fitted.
I'll have to have words with the garage. It's the third locally whose door I will not darken again with any of our vehicles. Life was much easier when we were near Lakeland Land Rover in Torver: not cheap, but you could rely on the work that was done. |
12th Jul 2023 9:05pm |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 321 |
I bought a pack of 100 stainless steel split pins to use on mine, they were cheap and I'll never be tempted to re use the old ones, just in case! Probably cheap rubbish r-clips with no spring to them, that fell out.
12th Jul 2023 11:18pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2034 |
Sounds like a nasty experience.
Whilst they aren’t my securing method of choice, I have never had any issues with R clips. As others have said they aren’t taking any load. As for the lack of pride/ability and workmanship of far too many garages nowadays… |
13th Jul 2023 7:04am |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1188 |
Mine has has r clips on for as long as I can remember and some 180k miles later still not had an issue. Mind you they're such a tight fit you need to pry them out so they're not going to wiggle out. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
17th Jul 2023 7:03pm |
