Home > Maintenance & Modifications > patch for A post gap? |
lolo Member Since: 18 Jul 2021 Location: Vaud Posts: 118 |
Hi,
Scotch-Weld™ Preformed Sealant Strip 5313 is what you are looking for. https://www.3m.com/3M/en_LB/p/d/v000117662/ Heat it in you hand like with modeling clay, than apply in the gap and tape over with Gorilla tape or any other kind of tape. Happy water ingress hunt Ps: you should clean up all this old black seal and have a clean surface all arourd so the door seal will better do its job |
9th Apr 2023 4:57pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1005 |
Thank you. I cleaned it up, applied new pads and sealant; now hoping for the best.. :-/
These were the butyl pads I was looking for https://www.lrworkshop.com/parts/LR028972 However, given p&p costs it was cheaper to buy 10m of alu butyl tape and cut off 2x 2cm strips May use the rest to patch up the barn's rain gutter, finally |
19th Apr 2023 7:37pm |
