Home > Puma (Tdci) > 2.2 injector oil seal change - parts? |
HTB Member Since: 24 Mar 2013 Location: Surrey Posts: 71 |
Having completd the job, for a 2.2 you'll definitely need:-
LR032070 SEAL INJECTOR x4 £9.50ea LR029962 BOLT x2 £ 2.76 ea and you might want.... LR058092 GASKET CYLINDER HEAD COVER x1 £ 41.05 ea LR037698G.TR GROMMET FUEL INJECTOR x4 £ 5.32 ea I used genuine Landrover parts for the stretch bolts. seals and cylinderhead cover. I used OEM for the grommets around the injectors. My grommets were brittle and non sealing, so was pleased I'd ordered new replacements. The cleaning kit was worth it. i also ordered a seal retrieval tool as I'd seen that sometimes these didn't come out with the injectors. only one seal stayed on the head, and the tool retrieved it first time. My 2012 manual said 7nm +360degrees for the stretch bolts. Click image to enlarge |
8th Mar 2023 7:14pm |
cretesimon Member Since: 01 Nov 2021 Location: heraklon Posts: 46 |
Take 4 copper seals for injectors 4 seals for injectors for the rocker cover 2 bolts and 2 seals for the bolts I believe
9th Mar 2023 8:12am |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 296 |
Might be worth double checking the final torque in the manual.
It’s been awhile since I removed and replaced mine, but seen to remember it’s was 7Nm then further rotation of 180 degrees. I went for new injector clamps (2) and fuel spill O rings (4). |
9th Mar 2023 2:26pm |
