Home > Puma (Tdci) > 40.000 km Service |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2109 |
Well,
Today our Defender went to the 40.000 km checking. Several things to be worried (not too much, but): a) Oil leak in the rear part of the transfer again b) Oil leak in the union between the rear prop shaft and the diff. c) Driver door stooper doesnt work d) Misaligned Rear door. So much oil leaks in 40.000 km! I don't like to imagine what will happens when the guarantee will finish. 4 days to make all this work, So we will see on Friday. Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
27th Jan 2009 3:13pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
What's the issue with your driver's door?
I noticed the other day that my driver's door doesn't stay open but just swings shut (mostly onto me as I'm climbing in). |
28th Jan 2009 1:43pm |
Atlantd
The same that you. And is quite awful in special when you are in a slope. Same problem was detected in the past in almost all doors. Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
28th Jan 2009 3:00pm |
I'd be interested to see if they fix the door stopper. I had just assumed there wasn't one
29th Jan 2009 5:46pm |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 365 |
Same here, just the drivers door,none of the others. Eveything else is OK though. 130 crew cab
98 V8 Disco |
29th Jan 2009 6:02pm |
All the doors should have it, rear door included (at least in mine)
In my case the passenger, the rear door and one of the 2d row doors has been fixed in previous visits to the dealers. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge Last edited by Eduardo on 29th Jan 2009 10:24pm. Edited 1 time in total |
29th Jan 2009 7:03pm |
Just I speak with the dealer.
Transfer leak was a bolt not sealed properly when they changed the seal some time ago. The leak in the rear diff was the seal (already changed) Driver door stopper were also fixed Brake pads changed Windscreen wippers changed Door seals also was adjusted Some greasing works Rear door adjusted So I'm ready to start my vacation period (2 weeks only ) In the family farm with some trips to the beach and to the mountains (I hope). I promise some photos... Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
29th Jan 2009 10:22pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Enjoy bud NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
30th Jan 2009 1:25am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Enjoy your holiday Ed. 2.4 90 XS
30th Jan 2009 10:38am |
