Home > In Car Electronics > Defender switch panel |
The Mud panel comprises two parts - the switch mount, which is flat, and then the outer bezel that is shaped to fit a Puma dash. It would be worth checking with them before buying but it looks like you could just use the switch mount on its own in a flat panel. You may have to drill some holes for screws or perhaps glue the mount to your dash panel. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
14th Oct 2022 10:40am |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1355 |
The switch panel from a Discovery2 may do what you want, but it's only got 6 switches and the Hazard Warning switch is a different size.
14th Oct 2022 11:33am |
MUD-0090 or MUD-0091 may also be an alternative.
https://www.mudstuff.co.uk/collections/wha...itch-mount https://www.mudstuff.co.uk/collections/wha...t-vertical |
14th Oct 2022 11:42am |
