Home > In Car Electronics > Blown Fuse - interior light circuit |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3616 |
remove the fuse, reinstate the interior light fitting and then refit the fuse.
see it it blows again; the interior light has a permanent live and the negative is switched so easy to blow the fuse if removing or refitting the light fitting guess how I know? DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
11th Sep 2022 8:57pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 721 |
You can blow the fuse just by changing the bulb I did.
Just takes the slightest misalignment to short. You should be ok if everything working again. |
12th Sep 2022 8:16am |
When I had mine apart to fit a third interior light, I fitted plasticard insulators to the backs of each unit avoid exactly this:
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
12th Sep 2022 8:57am |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1000 |
@LRA neat as always
Why LR decided to use the same fuse for light, clock, radio AND instrument cluster and OBD socket is beyond me. Maybe during development an engineer used slang for 'clock' and 'lights' (i.e. odometer, warning lights) and someone thought "oh, great, there's already a fuse for that. I can make my boss happy for re-using that one." |
12th Sep 2022 4:26pm |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 |
great news, thanks all, will look at insulating it
13th Sep 2022 9:02pm |
