- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Puma (Tdci) > 2.2 injector rocker cover seals. Don't make my mistake. |
itsdashy
2.2 injector rocker cover seals. Don't make my mistake. | |
I got a random eBay kit after having my injectors tested that seemed to fit into the rocker cover nicely but I then had one almightly and difficult to trace oil leak.
Turned out the seals were just too small to not eventually loosen and rode up the injector. Subsequently, it filled the valley with engine oil which would drip down the back of the engine to both sides of the gearbox and coat everything about.
Was a to diagnose but after getting new seals from Ford everything is nice and dry with the added bonus of not needing to Dinitrol the chassis for a bit.
30th Aug 2022 9:25pm |
