Home > Expedition & Overland > Roof top tent onto Cargobear Bars/Rack |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3323 |
Cant you fit the tent first and then load tent and bars on as a single unit onto the roof?
12th Feb 2022 6:28pm |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 746 |
That is one possible way.
The issue is that (I think) the roof rack is going to be a three bar affair from the front to just behind the middle of the roof with the tent picking up the rear bar of this and another bar at or towards the rear of the roof. The issue with setting up in this fashion is that the tent will piggy back the end of the roof rack bar and wouldn't be practical to take off complete. I will need to take the tent off at times for transporting kayaks for days out and maybe for family holidays if we take the ground tent. My current thinking is that if I get the Mount system it may be possible to have temporary boards that fit in for when more rack and or access is required when the tent isn't mounted. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
12th Feb 2022 6:35pm |
d.tribe Member Since: 11 Apr 2015 Location: hampshire Posts: 9 |
Just wondered how you got on with mounting your roof tent on the cargo bear rack system? I am also considering doing the same.
12th Jun 2022 4:47pm |
Jem_90 Member Since: 10 May 2019 Location: Oxon Posts: 49 |
Following this thread with interest, I have a cargo bear on my 110.
We built it in full then lifted onto the Landy. Want to get a RTT for it https://www.instagram.com/baltic_blue_defender/ |
13th Jun 2022 6:45am |
chris h Member Since: 09 Nov 2009 Location: West Devon Posts: 47 |
I use the RTT mounting system. I have a Overzone tent that has a cover secured below the tent. I couldn't get my fingers into the space, so
I bought some spacer and use the existing C rails. If I did it again, I would get bigger spacers and remove the C rails. It seems very solid. Click image to enlarge Click image to enlarge CHRIS 2009 110 SVX 60th Anniversary - Santorini Black |
13th Jun 2022 5:57pm |
