Home > Td5 > New Engine Noise |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2309 |
Are you sure it's not an exhaust gas leak? Check the manifold for leaks and also the flexible joint on the exhaust down pipe for cracks
1st Feb 2022 1:11pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5748 |
Turbo heat shield? 1999 Defender TD5 110
1st Feb 2022 1:16pm |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
Will check both suggestions but don’t think it’s exhaust manifold but you never know.
Just ordered a new oil centrifugal filter as this could become defective and cause similar noise. Will start with basics before taking cam cover off. 2007 TD5 90 Hard Top |
1st Feb 2022 1:35pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1825 |
You could go old school and get yourself a mechanics stethoscope, ie Lisle 52500.. cheaper ones out there but they don’t perform as well. Great for locating where noises are coming from.
1st Feb 2022 2:23pm |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 814 |
Could be one of a number of things.
Best thing would be to stand by the engine whilst someone revs it. Then you can try to locate the noise more accurately. Check the pulleys, as they can make odd noises. The hydraulic lash adjusters can make tapping noises, but usually that is most noticeable at idle. Hopefully it’s something simple and easy to resolve. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
1st Feb 2022 7:13pm |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 724 |
Watching the thread with interest as I am also trying to investigate a similar issue which is leading to a lot of head scratching! BORG - Bucks & Oxon 4x4 Response Group
2nd Feb 2022 7:54am |
M.J.Persius Member Since: 03 Apr 2021 Location: Ayrshire Posts: 17 |
Following also.
155,000 miles with a very similar issue that intermittently presents around 2500rpm. |
6th Mar 2022 2:35am |
Might have found the issue - and its not the engine.
Will know more in a few weeks. Still drives perfectly so not a major issue just curious. Will report back once diagnosed 2007 TD5 90 Hard Top |
10th Mar 2022 10:46pm |
Problem found...
Spigot bearing at the end of gearbox output shaft completely disintegrated. Output shaft then suffered with excessive play causing the noise to be transferred through engine and therefore difficult to pinpoint. New gearbox from Ashcroft Engineering installed along with their upgraded billet release bearing, new clutch and pressure plate (as a precaution) and new spigot bearing. Noise gone, gearbox tight and Landy drives like new again. Just put through yearly MOT and passed first time. So now its sorted it is a pity that it will be going up for sale soon. After nearly 15 years of ownership it is time for someone else to enjoy a great Defender. 2007 TD5 90 Hard Top |
19th Jun 2022 9:47pm |
