Home > Tdi > Land Rover 90 1986 |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4406 |
Hi. So there should be two small bore hoses attached to the turbo side of the engine bay. One is short and links from the turbo outlet to the turbo actuator. The second will go from the turbo around the engine to the injector pump, this is the vacuum advance pipe.
Which one are you referring to? |
24th Jan 2022 5:40pm |
JLRyall Member Since: 24 Jan 2022 Location: Hampshire Posts: 7 |
Hello,
Yes it's the pipe which goes across to the injector pump |
24th Jan 2022 5:46pm |
Ok. Excuse the google photo. You can see the rubber actuator hose on this turbo. The hose that goes to the injector pump connects here and then snakes around to the I.pump.
IIRC correctly the pipe has a short piece of rubber hose that attaches to the turbo, which then turns in to a solid pipe from there. Click image to enlarge Last edited by geobloke on 24th Jan 2022 6:12pm. Edited 1 time in total |
24th Jan 2022 6:05pm |
Sorry how can i see the photo?
24th Jan 2022 6:08pm |
Sorry, it wouldn't upload so had to alter it to get it to
24th Jan 2022 6:13pm |
Ok so looking at this photo again, the brass union has broken off and is dripping oil. Pipe has probably just fallen down. But you will need a new union. |
24th Jan 2022 6:14pm |
Yes..... what does that small unit look like and where can i get one?
Or what is it called so i can find one> |
24th Jan 2022 6:15pm |
A quick search has shown that they are not easy to find. You have two choices. Call up Turbo Technics and ask for a spare one, I am positive they must have a drawer full of them.
Or if you are looking for a quick DIY fix then plug the hole and fit something like this in to the outlet hose elbow and run the pipe to the injector pump https://www.ebay.co.uk/itm/273493990397?ha...SwNURbRW8y |
24th Jan 2022 6:28pm |
Actually you have a third, forth and fifth option:
1) Replacement standard turbo - https://www.lrdirect.com/err4802-turbocharger-300tdi 2) Replacement uprated turbo - https://www.allisport.com/shop/performance...bocharger/ 3) Second hand eBay turbo - https://www.ebay.co.uk/itm/284611447430?ha...ondition=4 For example. Plenty of others on there More expensive but they will both come with the unions and you get to upgrade your Defender as well |
24th Jan 2022 6:33pm |
Thankyou very much
thats helpful will be back if i need any further help |
24th Jan 2022 6:37pm |
Sure thing. Let us know what you decide to go with
24th Jan 2022 7:00pm |
