Home > Td5 > TD5 uncomfortable? |
TDfive Member Since: 02 Sep 2008 Location: somerset Posts: 51 |
i have a winter pack in mine ie; heated front and rear screen and heated seats they more than make up for the heater in the td5 i know it dont get quite as cold as you get but a nice warm bum and back makes ya feel a whole lot mor comfortable ------------------------------------------------------- 05 110 crew cab td5 1987 90 tc TD/200TDI DISCO CONVERTION |
20th Mar 2009 7:57pm |
EdF Member Since: 22 Jun 2009 Location: 15m west Inverness Posts: 24 |
Hi Guys, I thought I'd chip in my six pennorth to this thread, my first post on this forum. I'm on my 16th and 17th Landies (sad, I know), a 90 TD5 and a Disco3. It's my eighth of the former and first of the latter. I've spent a good deal of time trying to make 90's more comfortable and may have got this one about as good as possible within reason. It has Bilstein black shocks all round, new RR1 springs on the front and standard springs on the back. I tried Disco1 springs on the back but the ride was too low, and soggy with a load in the back.. (don't quote me, it may be Disco 1 springs on the front, doh!). With standard suspension and only 23k on the clock, hitting a small pothole was like driving over a kerb at 50mph. Much better now..
After eight 90's I can assure you that the heater output varies a LOT between motors. As with my previous two 90 TD5's, I had the final drive ratio changed to that of a Disco2 at Ashcrofts in Luton (c.£600), which makes it much quieter and (IMHO) doesn't affect towing,(Disco2's don't have any bother towing..) and it'll do 90mph in 4th gear (only tried once!) in standard tune. And I tow a very heavy horse trailer with nag/s quite often. If you would like better(?) suspension, I know someone who will convert a 90 to air suspension for £2500 with 10 inches of travel. I can't comment on the newer 90 Transit as I've never driven one, but isn't choosing between the two down to price? One can buy a cheap TD5 but not a cheap TDCi..? I've never had a problem with any TD5, and I've also had two Disco2 TD5's.. If you need more 90 legroom, a company called MUD sell a bulkhead removal bar to remove the bulkhead behind the seats and also new seat rails which give loads of legroom.. Being 5'10" I don't need either.. Make the most of this life, you may not have skis or a Landy in the next. |
22nd Jun 2009 9:34pm |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 800 |
Welcome EdF - skis & Landys = agreed.
Just out of interest - I think the Pumas have Disco 1 springs all-round, SWs anyway... The ride is definitely more supple than my last 90 (a 50th, which may have different springs again to a standard 90), but it doesn't corner as 'flat'. With my back though, I'm happy with the compromise. |
23rd Jun 2009 11:21am |
Ah, the Disco springs would make it a bit softer. It's strange how some people react to non-standard changes. I posted a thread on another forum about what I'd done and someone replied that he thought my 90 would 'throw itself off the road' because I had fitted softer springs and implied that it didn't because I had anti-roll bars (standard on mine). There seems to be a notion amongst some owners that one should fit heavy duty springs to any 90,no matter what it's used for, but the fact is that a 90 HAS heavy duty springs - for a Discovery - fitted as standard.. And the Disco 2 weighs 400Kg more than a 90.. He was basing his theory on a ride he had had in someone else's 90, which had softer springs - probably worn-out ones.. A pal I sold an earlier 90 to also found Disco2 springs too soft on the back, something I found too, but considering the weight of the two vehicles, I found that surprising. New springs from Paddocks are remarkably cheap, from as little as £9. Need the correct length and rate though.. This may be interesting to some.. Passed down from the compiler. http://members.shaw.ca/jbarge/springinfo.html Make the most of this life, you may not have skis or a Landy in the next.
23rd Jun 2009 4:03pm |
Definitely need the anti-roll bars, mine being a County didn't have them as standard - I test drove it and scared myself at the first roundabout! Had them fitted straight away.
I would guess that so long as the shocks were matched to the spring rates, softer or harder would be ok according to preference/usage? I could never understand why LR couldn't make a 90 more supple as standard without compromising the load carrying capability. Maybe it would need a Boge or similar... The latest changes to spring and shocks have helped, only slightly though, and at minimal cost I suppose! On this note, I'm guessing a TD5 can have the later Puma shocks and springs added without worrying about insurance implications? |
24th Jun 2009 9:45am |
Don't know how you would match shocks to spring rates, it all seems a case of 'suck it and see'. When trawling through after market Land Rover suspension ads, all you find is 'heavy duty this and 2 inch lift that', no mention of comfort anywhere. Is it assumed everyone drives offroad? You're right, Land Rover assume everyone buying a 90/110 is either a municipal authority, the armed forces or a farmer wishing to tow a trailer full of pigs over a field and to market. As far as I know, the only concession they ever made to normal mortals was to put Disco final drive gearing into 'County' models (I had one, a V8, and it was 'supple', only because the bushes were shot!) but they no longer do that any longer. (but I don't know about the Puma mdels, too new for me...) Make the most of this life, you may not have skis or a Landy in the next.
24th Jun 2009 9:55am |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
Anti roll bars come on a county if you tick the option box for the Boost alloys when ordering |
24th Jun 2009 11:20am |
That follows - mine is on steels. Wonder what the thinking is behind that... alloys make you corner faster? Suppose it's to help keep the cost of the basic models down. |
24th Jun 2009 1:03pm |
Hope they did`nt charge you to much for the anti roll bars, as the boost option c/w roll bars is about £800
24th Jun 2009 1:28pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
After driving many Land Rovers all shapes and sizes, I would say that a good HD shock and spring package is worth its weight in gold. I have a 91 Discovery and I changed a 1 year old set of L/R shocks and springs for a HD setup and the change was amazing- I do off-road but the handling on the road is comparable to a later Discovery with ARBs. The army's wolf land rovers also corner a lot better than a regular one, and that has a HD option- but now been pushed to use ARBs because of the excess weitght in the back. Once my puma is out of its warranty I will be looking at a HD package- not neccesarily a lift but deffo HD. It also isn't harsh on bumps- if anything it is more bareable. Glyn. |
24th Jun 2009 1:59pm |
I bought mine 2nd hand from a LR dealer - the fitting of the ARBs was negotiated in the purchase deal (after aforementioned test drive!)... IIRC the LR stock charge for retro-fitting ARBs is £500. Agree that if buying from new, it wouldn't make sense to add ARBs to the options without alloys, although if you were going for the 'heritage' look (which mine has) and didn't want alloys (or to roll like a 2CV) I'm sure you could get them thrown in. |
24th Jun 2009 4:18pm |
