Home > Puma (Tdci) > Exhaust Gas Recirculation Circuit Range/Performance P0404 |
ak615 Member Since: 22 Aug 2018 Location: essex Posts: 174 |
Had a similar problem with mine a week or so ago, I've put injector and turbo cleaner in the tank and touch wood the fault hasn't re occurred
27th Dec 2021 4:54pm |
Landymatt Member Since: 31 Dec 2018 Location: York Posts: 191 |
I had the same problem and cured it by getting a BAS remap via the tool that Pete Bell sends out,
Cheers, Matt edit - I had the same fault code appear… possibly the same problem but not necessarily |
27th Dec 2021 5:05pm |
pilsburypie Member Since: 19 Jul 2021 Location: Birmingham Posts: 173 |
Cheers chaps. I am tempted in the near future to get a stage 1 and ERG blank. Just in a bit of a fix for tomorrow. I have cleared the code but not driven since as I’ve had a drink😏
Think my option for the long drive and week away is to take the OBD reader and keep resetting if it comes up. Then on return, look at getting sorted. |
27th Dec 2021 5:35pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2005 |
Maybe giving it a damm good thrashing up the road might help clear things out.
27th Dec 2021 8:07pm |
So I’ve cleared the code (and stopped drinking) and took the car for a 2 minute drive round the block. Engine light has not come back on and it drives fine.
So plan to drive to Cornwall tomorrow morning as planned from the Midlands….. 3.5 hours of mainly motorway. So if needing a blow out is what is required, that should do it. Taking the reader with me to reset if needed. Never had breakdown cover as I’ve always been very self sufficient….. anyone know if I do end up incapacitated in Cornwall if you can just sign up to AA or the likes right then and there and get towed back under their cover? Or do you have to be a member before breaking down?!!! |
27th Dec 2021 8:46pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19608 |
If you don’t already, consider running Millers diesel additive as soon as you can.
It isn’t a miracle product but may well help in your situation in due course. I use it all the time, and it will run better and cleaner too. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
27th Dec 2021 11:16pm |
Cheers. I might see if I can pick some up tomorrow. For me at the moment it’s all about getting through this next week. If I’m in limp mode on the M5 I’m in the !
27th Dec 2021 11:43pm |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
I agree with DAZ110. A good long run getting everything heated up and cleaned out does wonders with the 2.2. It doesn´t like short journeys at all. 1998 Tdi 90 SW,
2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTs, Recaro CSs, anorak, wellingtons |
28th Dec 2021 8:04am |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 315 |
I’m sure my 2.2 runs much better since I started putting Redex in the tank (not tried Millers) & totally agree it needs a good blast down the motorway now & again to give it a good clean through. Premium diesel seemed to have a positive effect too, but I’ve settled on standard diesel & a splash of Redex. It’s quite subjective though, in my mind my engine is sparkling clean inside!
28th Dec 2021 8:28am |
Same system as me, regular diesel and Millers. Stick to that permanently.
Typically 99% of the time use Esso too, not that it’s that critical. Diesel techs commonly swear by it, I was skeptical at first but now use permanently. K9F on here started me off on it. Being parked up periods of time and short trips definitely do cake things things up. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
28th Dec 2021 7:47pm |
So you recon there’s a difference between supermarket fuels and Esso? There’s certainly a difference in price…. £5-6/tank.
Would you believe that I popped into Aldi this morning to pick up a few basics to last us the first day of holiday…. They only had diesel redex twin pack…. So bought some and banged a bottle in my full tank. Now sitting in a holiday home in Cornwall after an uneventful journey and no engine warning light. Fingers crossed for the rest of the week. |
28th Dec 2021 8:03pm |
Glad you made it all good. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
28th Dec 2021 8:52pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 956 |
Prevention is better than cure with your 2.2 especially if you only do short journeys. I would recommend a fuel cleaning additive every 6months and then use Millers on every fill.
DPF’s are crazy, burn three times the fuel to save half the particulates. Get rid of it and let your engine perform at its best Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
29th Dec 2021 8:25am |
Back from Holiday. Many hundreds of miles covered and no issues. 2 full tanks with that redex went through, so hopefully that has done some sort of cleaning.
At least the fix was removal of the fault code. One of the easier ones for the time being at least… |
3rd Jan 2022 2:51pm |
