Home > Maintenance & Modifications > Battery maintainer advice needed |
chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 409 |
If you have an automatic charging relay I would charge the main battery and then the relay will trip and charge the aux when the main is charged
In fact that is what Cyrix recommend it seems |
28th Nov 2021 10:02pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1871 |
As above,
I have 2 optimas and a ctek, the solenoid will automatically switch over when the main battery is satisfied. If you have DRLs with the voltage sensor you may need to fit an inline switch……found that out! 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
28th Nov 2021 11:02pm |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
thanks gents Roaming around 🇳🇴🇨🇭
29th Nov 2021 8:52am |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
Wire it in to whichever is easier, it will connect both and the effect will be the same.
29th Nov 2021 9:15pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
I've never had any luck charging this way through a VSR. I've always had the problem that when the battery being charged reaches the connection voltage to trigger the VSR, the other battery then drags the voltage back down to the point the VSR disconnects again. Then just get a slow cycle of the VSR opening and closing.
I can't figure out why this happens, but it does. It may my charger doesn't have a big enough current (3.8a) to sustain the voltage when the 2nd battery connects. 2007 110 TDCi Station Wagon XS |
29th Nov 2021 9:53pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 996 |
Bluest it's probably your charger being too weak. I have a CTEK 10 Amps and the VSR (National Luna) will disconnect if one battery's charge is substantially lower than the other one's, hence dragging the combined voltage below the VSR's threshold. With a weaker charger this could happen earlier.
Because of that I have wired a switch into the VSRs supply to switch it off. Then I charge both batteries separately (each one having their own CTEK plug). This is also important when you recondition a flat battery! |
29th Nov 2021 10:47pm |
